narcopletic pc
my pc fans are going crazy right now - i mean it sounds like its gonna fly off - i just cleaned out tower as i always do every couple months and when i restarted this time it seem to overheat - the fans max out over the littlest applications - one thing that i noticed is that the "goo" between the cpu housing and the heat sink is dry - i plan on adding some arctic ice a.s.a.p but can something so small create this prob - or do i have other issues i need to look into? - thanx - sorry for all the noob questions but im learning more then ever on this forum - thanx for everyones patience and support
- HP
- Phenom-9150e (A) 1.8 GHz (65W) 2000 MHz Hyper Transport 1.0
- ECS MCP61PM-HM
- 7Gig PC2-6400 MB/sec 240 pin, DDR2 SDRAM
- GeForce 6150SE nForce 430 (onboard)
- High Definition 8-channel audio ALC 888S chipset
- w2207h 22" lcd wide-screen monitor HDMI
- 1680x1050
- 640 GB SATA 3G (3.0 Gb/sec) 7200 rpm
- Laser
- HP multimedia
- RR turbo 10meg down 1 up
