Optiarc AD-7170S problems
Kevin360
I've just bought an Optiarc AD-7170S Sata DVD burner. The problem is, it isn't recognized by Vista. I'm running Vista Ultimate x64. I have a Phenom 9550 Quad, 4 GB DDR2-800, and a Gigabte MA78GM-S2H motherboard. I've tried to download SATA/RAID controller drivers from the Gigabyte site, but Vista doesn't seem to be able to install them, or to properly download them for that matter.
I've tried emulating IDE in my BIOS, but that failed too.
I'm at a loss here, does somebody here know what to do?
Thanks in advance,
Kevin.
Vista should have drivers quite suitable for your burner. But it does sound like you might be having problems between Vista and the SATA interface on your motherboard.
... but Vista doesn't seem to be able to install them, or to properly download them for that matter....
That seems to be a strange error. Do you regularly have issues downloading?
Have you tried downloading them with Firefox or Opera? Have you tried downloading them on another computer and copying them over?
Thanks for your reply.
I've tried to download it with both IE and Firefox, both don't work. And I never have problems with downloading from websites.
But I will try to download it at another computer, if you think it is probably the connection Vista/Motherboard.
I'll post again in it did or didn't work.
Thanks again,
Kevin.
I'm running an AD-7191S and I haven't had any issues like that.
Do you have the latest bios update?
    RJ's Toyz/HOTROD
    DFI LanParty UT P45-T2RS
    G.SKILL 8GB (4 x 2GB)
    24" and 22" Acer LCDs
    1920 x 1200 / 1680 x 1050
    PC Power & Cooling 1200W
    Cooler Master HAF932
    Logitech G9 @28grams
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
Have you tried different SATA ports/cables and power supply connections?
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    Samsung T190 1440X900
    1440X900
    2X Seagate 120 (OS's) IDE 1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
