OEM serial with a retail DVD
JWhipple
I have a new laptop that I got from Dell and want to do a 100% clean Vista install on it.
I have the DVD that came with it to restore vista, which I don't want to use because of all the extra crapola that it installs.
I also have an x32 Vista DVD that came with my VIsta Upgrade retail package.
My question is - since I have the serial number that came with the laptop, will it work with the retail DVD even though it's an OEM serial?
Thanks!
    AMD Athlon 64x2 3800+ (Socket 939)
    MSI K8N SLI
    2GB Corsair DDR in dual channel mode
    2x BFG Geforce 7600GT in SLI mode
    Soundblaster Audigy 2
    Big ol' 21 inch Gateway LCD monitor
    160GB SATA1 (Western Digital) 500GB USB External (Western Digital)
    600 Watt BFG
    Logitech G7
    Logitech G15
No, The Serial that came with the OEM, will only work with that version of Vista. You Can't interchange Serial's between Versions.
    Dell Latitude D530
    Intell Core Duo T7250 @2.00 GHz
    Not sure-Dont see it under Device Manager
    4.0 GHZ
    SigmaTel High Def
    Intel Mobile 965 Express chipset Family
    1024x768
    Logitech Wireless
    64-130 Mpbs
    Also Running: Server 2k3 and Vista Business in VPC.
Hello JWhipple,
If you are not using the product key number for the 32 bit retail Upgrade Vista installation DVD, then you could use it to do a clean install with the upgrade DVD instead if you like. This tutorial will help show you how to if needed.
http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html
Since the other one is a retail version, you could order the 64 bit DVD version of it for around $9.99 S&H directly from Microsoft and use it instead with the 32 bit retail upgrade product key number to install.
Windows Vista Alternate Media
Perhaps a little clarification is neccessary.
The laptop came with OEM Vista Ultimate.
The DVD that came with it is their "special" Vista Ultimate OEM load with all the other proloaded garbage.
The DVD that I have is the Vista Ultimate upgrade, which I know how to do a full-blown install out of.
So, with that having been said, since I have a Vista Ultimate OEM serial number, and a Vista Ultimate upgrade DVD, will that OEM serial number work with the upgrade?
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
From all the tests I have done it should work fine ;)
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
