Odbc
Try doing a restart and logging in as administrator.
    16GB DDR667
    SAS RAID
administrative tools - Data Sources (ODBC). You can create the DSNs for each database.
    16GB DDR667
    SAS RAID
I use SQL 2000 and 2005 databases. I create the database in SQL and point the DSN to it. Do you have the access database created to point the DSN to ?
    16GB DDR667
    SAS RAID
Are you creating the correct DSN for it. Does it need a user or system DSN. On SQL server, its system DSN. Are you choosing the correct data source type. For SQL 2000 and 2005, its SQL Server. Some databases are ODBC.
    16GB DDR667
    SAS RAID
What is the database engine and services?
    16GB DDR667
    SAS RAID
Are you running this database out of Access or SQL Server? When I connect the DSN, I choose the server name, database name, and SQL authenication to configure the SQL DSN.
    16GB DDR667
    SAS RAID
