not deleteing folder
ashokapex
Hi ,
i found one issuse in vista 64, when i install any installer(msi) like yahoo or any other,
i saw empty folder get created in 'C:\Users\username\AppData\Roaming\Yahoo',
but when i uninstall this software , this folder not get deleted,
but ideally this folder should get erased
i notice this happen only in vista 64 , not in vista 32 ??
any one know this thing how to fix ?
is this known- issuse.
Thanks in avdance.
It should work for Vista, where did you have the problem?
Make sure you use the elevated command prompt
I dont want to delete from command prompt , i want to delete from installer while installation.
i dont want to delete manually,
because this folder gte created on installation and it happen with any installer , try yahoo or other installer for vista 64
