not able to load dll from system32
apfx
Hello everyone,
I've got an 32 bit application that uses a data feed plugin
two .dll components of this plugin need to be placed in the application folder but the third which is an API needs to go to Windows>system32 folder.
The application can not load under Vista Home Premium x64 the API .dll residing in system 32.
needless to say that everything worked fine with Windows XP.
I have no clue where the problem is.
Is there any security Vista that I'm not aware of?
Any help is appreciated
Hello Apfx, and welcome to Vista Forums.
I'm not sure if this is your problem or not, but right click on the .dll file you added and see if there is a Unblock button under the General tab. If there is, then click on it to unblock the file. If not, then it is already unblocked and I do not know what else to suggest.
Hello Shawn,
There is no Unblock button in the Properties>General tab, I have attached the file permissions status for users
BTW, your Tutorials have been very useful, thanks and keep up the good job.
What is the actual error and what is in the event viewer on the error.
    16GB DDR667
    SAS RAID
Hello Michael,
I have attached the error message but I can not locate the error it in the
Event Viewer (Local)> Summary of Administrative Events>Errors
or
Custom Views > Administrative Events
and
Windows Logs> Applications
Boot your computer with administrator and try it. Does it work?
    16GB DDR667
    SAS RAID
