not able to access my C: drive
yashsrawat
Hi
Need your help. Yesterday evening i was working on my system and was changing the security setting of one of application, but after doing that....
I am not able to access my C: drive, my whole data is in C drive.
Need urgent help to fix this issue.
Yash Rawat
Hi
Yash Rawat
Hello Yash Rawat,
Welcome to Vista Forums!
The easy answer is, undo the security setting and see if that 'fixes' the problem.
Keep us informed.
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Hello.
Then we will need the particulars, what exactly did you do!
More information.
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Hi
I have open one folder in c drive, click on security tab>than chose the guest access>uncheck the edit and read access.
It show me one message, by doing this, it will reduced the security on your local drive.... and i click yes.
after that i am getting this error that i am not able to access my C drive.
I have two acccont on my systme :-1) Guest,2)administrator.
Thanks
Yash
Can you take ownership of C:? In the security tab under advanced, owner. Take ownership with your user.
Enable your administrator account. Set a password on it. Boot up using it instead. ctrl-alt-del x 2 should bring you a login box.
    16GB DDR667
    SAS RAID
