no wireless connection
calmat
hi everyone
my internet connection will only connect using an ethernet cable, when I umplug cable
I lose the connection. I have a new router which seems to be working
properly i.e. all the lights are on. I have a wireless internet button on the computer
that should flash orange when on, but this is not working.
can anyone please help.
ROUTER IS - Technicolor Gateway TG582N
COMPUTER IS - Acer 5920
regards calmat
You need to setup th connection.
Most routers come secured, anfd so you must go through the connection manager, and put the proper default key into the passkey section.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
have you done the connection wizard without the network cable? Because I dont berlieve that sets the laptop up, just the router.
I sually dont use a wizard, just find my router in the list, and connect manually.
HAve you tried that?
hi patomb
When I turned on my computer this morning my wireless connection light
has come back on any ideas why this has happened. I can now remove ethernet
cable and the connection does not fail.
calmat
Nope, no idea.
Btw, I have an acer 8930, and that light is also a button, which turns the wifi antenea on and off.
You might have hit that by accident.
Atheros
Tech Support Guy System Info Utility version 1.0.0.2
OS Version: Microsoft® Windows Vista™ Home Basic, Service Pack 2, 32 bit
Processor: Intel(R) Pentium(R) Dual CPU T3200 @ 2.00GHz, x64 Family 6 Model 15 Stepping 13
Processor Count: 2
RAM: 3002 Mb
Graphics Card: Mobile Intel(R) 4 Series Express Chipset Family, 1309 Mb
Hard Drives: C: Total - 296659 MB, Free - 159066 MB; D: Total - 8581 MB, Free - 1630 MB;
Motherboard: Wistron, 3612
Antivirus: AVG Anti-Virus Free Edition 2012, Updated and Enabled
Hi!
I accidentally uninstalled something called Atheros... and my Internet stopped wotking. I have no idea of what to do or even what it is I have uninstalled...
Someone could help me?
Thank you!
You need to go to the manufactuers webpage of your laptop, and go to the drivers section. Usually in support or downloads, and get the network drivers.
You can download them on any computer and save them to a usb stick, then run them on the laptop.
Atheros
Processor Count: 2
RAM: 3002 Mb
Hi!
Thank you!
