This is a long post but 'please' try to hang in there.
I will bet that None of you have seen a problem like this before!
For over a month, I couldn't open 'anything' on my pc without some difficult work-a-rounds.
Browsers wouldn't launch, tools and apps wouldn't open and access denied would pop up on any system tool that I tried to use.
I did stumble upon a way (described below) to open a browser but that wouldn't help with the other stuff!
It was only when I ran the software tool JRT (junkremovaltool) that everything went back to normal .. EVERYTHING WORKED!!!
Everything worked until I booted the next day and every boot after that!
Every time I power on, I have to do my work-a-round (again .. described below) to get to the JRT tool to get things back to normal!
The kicker is that the tool doesn't clean or delete anything after that first run!
(I still have to run it though, every time I boot!)
My Work-a-round:
(only way to open a browser before I run JRT)
Routine:
1) Click on Start
2) Go to Programs/Accessories
3) Click System Tools
4) Click Windows Easy Transfer
(new window opens)
5) Click on link Go to web page for further information.
6) Click next
(new page)
7) Click on the X (close) button on the new page
8) Click on are you sure you want to cancel easy transfer?
9) Click Yes
10) Microsoft web page opens up as well as my home page (two tabs/windows).
11) I go to the JRT web site and 'run' the program
(12) JRT runs and ...
13) Back to normal, everything works normally again.
(Until next boot time)
I have to run JRT instead of downloading it because Nothing will function (including JRT) Until I run a scan with JRT.
If possible .. I am going to try and get the software (JRT) to run at startup!
Maybe I can eliminate steps 1 thru 12 then?
Think it'll work? 8)
I'm desperate. 8)
I have included links to two of JRT's finished scan results.
The first is the original and everything that the tool removed.
The second is how every other finished scan looks.
I don't get it?
Is the clearing of the Event Logs by JRT returning my pc to functioning properly?
(JRT owner says no)
That is all that is in the logs ,, except the very first one.
Only the first one (scan) from days ago has loads of stuff in it.
First time the tool was used ..
JRT #1 - Pastebin.com
All Others ...
ALL THE REST - Pastebin.com
BTW: The JRT creator doesn't know why the tool works for me either!
I know this was a long ranting post and if you hung in there .. I Thank You!
My Work-a-round:
Routine:
1) Click on Start
(new window opens)
6) Click next
(new page)
9) Click Yes
I'm desperate. 8)
I don't get it?
(JRT owner says no)
All Others ...
- Gateway FX4710-UB802A
- 2.50 gigahertz Intel Core2 Quad Q9300
- 4094 Megabytes Usable Installed Memory
- NVIDIA GeForce 210
