No Sound
3swordlilies
I upgraded to Vista two days ago and then had the "no audio device found" problem. After trying several different things, I located a SigmaTel HD Audio Codec through Dell (I have a Dell Diminsion E510 w/Zylux speakers). Now, the "no audio device found" seems to be fixed--in that the little red box with the x is gone, and the volume indicator shows the volume is going up and down when I'm testing. Of course, I still can't hear any sound. I'm at a loss. I've unplugged the speakers several time (they make a nice humming when I plug them back in so I don't think they're the problem). I've rebooted so many times I've lost count. Any suggestions?
    Dell Diminsion E50
Can you right click on the speaker icon, choose playback devices, then do you see a tick next an audio device:
Go to its properties and make sure both boxes are ticked in the advanced under exclusive mode.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
There's a tick next to the audio device, and both boxes are ticked under advanced. I'm new here...I have no idea what a PM is :)
    Dell Diminsion E50
PM is private message. Does device manager show any exclamation points? Even so, in device manager, what is your sound device. We can try uninstalling the driver, rebooting, then reinstalling a new sound driver.
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
Device manager doesn't show any exclamation points. Under "Sound, video and game controllers," it lists "SigmaTel High Definition Audio CODEC." My entire system came from Dell when I originally purchased it. On the back of the subwoofer, it says, "Zylux Multi Media Computer Speaker System." Originally, I thought maybe I had the wrong driver, but I think SigmaTel makes Zylux.
I tried uninstalling the driver. When I rebooted, Vista automatically reinstalled the SigmaTel driver. Do you think I should completely remove the software when I uninstall the driver? Do you think I should use a different driver? During my "no audio device found" problem, I tried several different ones that didn't work.
    Dell Diminsion E50
3swordlillies
Do you have green lights showing when sound is being produced...
or are the green bars showing anything when sound is being produced:~
    Intel Core 2 Quad Q6600 G0 St
    Asus STRIKER EXTREME 680I SLI
    Corsair 4GB Kit (4x1GB) DDR2 800MHz/PC2-6400 XMS2 Memory
    Point Of View 8800GT 512MB GDD
    Soundmax 5.1
    Samsung 46"
    1080P
    1x WD Raptor WD360ADFD 36GB SATA 10KRPM 16MB Cache 1x WD Raptor WD740DFD 74GB SATA 10KRPM 16MB Cache
    Coolermaster 600W
    Coolermaster nVidia
    Arctic Cooling Extreme
    MS Wireless Laser mouse 8000
    MS Wireless Entertainment Keyboard 7000
    1.2mb & 10mb
I've heard of this problem before but it seems as if the Sigma driver just doesn't work. To test, can you try out a USB sound card such as the X-FI Creative go! USB?
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
I think you may have the wrong driver installed. Please re-check this and then show me what it says on your sound window.
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
    Soundmax 5.1
    Samsung 46"
    1080P
    Coolermaster 600W
    Coolermaster nVidia
    1.2mb & 10mb
