No sound
jasonjxsoon
This worked for me before but I messed it up.
I used to be able to record the sound coming from my computer and play it to my microphone right away as it goes.
Meaning when I record something, it would record whatever is playing on the computer.
But I forgot how to make that setting.
Any tips?
I really need this fixed
thanks
You just need to change the default audio device go into control panel>sound>recording and right click on the Stereo mix and set to default device if you want to record sound from your screen or select microphone if you want to record voice
    Toshiba Satellite Pro l300
    Intel(R) Celeron(R) CPU 550 @ 2.00GHz
    Intel Corp. 88395664Q
    DDR2, PC2-5300 (333 MHz), 1024 MBytes, Hyundai Electronics,DDR2, PC2-5300 (333 MHz), 2048 MBytes, Ap
    Realtek HD Audio
    Matte screen
    1024 x 768 x 4294967296 colors
    120gb SATA 2.5inch FUJITSU MHZ2120BH G1 ATA Device
    Notebook
    Fan cooled
    Logitech Cordless Optical
    Logitech Cordless Desktop EX110
    256Kbps
    I like Spore,Rabbits and I'm a Computer Freak.
wow you just fixed a week of frustration.
i checked it before but it din't seem too work.
I love you man. keeping this thread in case the problem pops up and i forgot.
I'm not really to sure about that one.:confused:.
Mine is quite too.:(
Does turning up the speakers to full make a difference??:sarc:
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
What program are you using to record??
could you possibly give me an idea on what your trying to do.:sarc:
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
im not recording anything,
im just using it as my microphone to play something
or just using my sound recorder on the computer.
it isint playing loud at all. =/
I'm Really not sure how to fix it. Why do you need to listen to whats on your computer using the microphone rather than just using the speakers?:D
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
Keep your Microphone set as Stereo Mix Then go into Messenger and click tools>Audio and Video Setup> Then Drag the microphone meter right up>Click Finish.
(If you cant see tools and stuff press F-10)
Hope that works;)
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
Why dont you just send your friend the song?
I just think that the sound can only record at a low volume.
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
    Realtek HD Audio
    Matte screen
    Notebook
    Fan cooled
    256Kbps
