No sound?
BaileeNeedsHelp
I have a Toshiba satellite L300 and its running vista.
My speakers work perfectly but when i plug headphones in,
the sound continues play on the speakers and NO sound us heard through the headphones. Can anybody please help me out here?
A small problem, but its overly bugging me.. :(:cry:
My computer is:
a Toshiba L300 Satellite
Model: PSLB8A-04S004 ( if that helps )
Intel Pentium Dual-Core.
i think its a Home Premium 32bit, im not overly sure..
any help would be overly appreciated
Thanks!
Hello Bailee,
Welcome to the Forum.
Sounds like you didn't push the jack all the way into the socket, or the socket is broken. If your machine is brand new there is possibility the socket has tight fit. Try to plug the jack few times so the connectors inside will settle down.
Hopefully it will help...:)
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
Thank you for your reply Martee.
I have indeed tried pushing it in all the way, and it is very reluctent to go in. and when i get the plug into the socket and try to pull it out, it merely takes alot of effort..
Is it a possiblity that water has gotten in there and corrupted the output?
And im only a teenage girl, and i don't really want to mention this to dad haha.
He will shoot me, but i noticed there were alot of probelms vista were having with audio. afew weeks ago i had a probelm the exact opposite to this, my headphones wouldwork, but my speakers wouldnt.
i was browsing through the internet trying to have a DIY porblem fix and i got it. so i thought this would be an easy fix.. guessing its not?
Hello Bailee,
I'm really sorry, I've got no idea how to help you in this. :( The headphones should work when you plug them in. The speakers should be mute at the same time. My only suggestion is to send your lappy to repair.
Your dad will understand this, I'm sure. It's not your fault, right. :)
Cheers...:D
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
Sounds to me like the socket's broken. Definitely some wiring screw up back in there... when the plug's pushed in it's making the 'switch' for the speakers.
    Intel Core i7 965 Extreme Edition
    Asus P6T Deluxe V2
    6GB Corsair Dominator 1600
    eVGA GeForce GTX285 SSC Edition
    Creative Labs Audigy 2 ZS Professional
    24" Gateway w/ Faroudja HD
    1920x1200
    2-Seagate 7200 500 GB 32MB cache 1-Seagate 7200 750 GB 32MB cache 1-Seagate 7200 320 GB 16MB cache
    Antec 850w
    Thermaltake Armor+MX
    Cooler Master Hyper N520
    Logitech 3200
    Logitech 3200 Wireless Desktop
    30Mb/10Mb up
    LG BR/DVD/CD Burner, HP Deskjet 1220C, HP Officejet 7590, Philips 5.1, Gateway MP8708 laptop running XP.
Thank you both for your replies.
i was really hoping not to have it sent away, but hey. i tried..
i think i did spill water on it an one point, but i was very sure that it got nowhere near the computer.
Thank you for your help, and i shall try to have it sent off.
i am having the same issue on a gateway desktop and when i go threw the settings and hit the test button they work and when i unplug the speakers in the back and then plug the headphones in they also work fine
