axolotl459
yesterday I had sound on my dell Inspiron. Today I have no sound and the small icon on the tool bar has disappeared. A look at sound on the control panel leaves me baffled. help please
Ian
Ian
I see these two options:
Speakers/Headphones
Sigmatel high definition audio CODEC
working. There is a small green circle with a tick inside it.
Digitil Output Device (SPDIF Out)
working. There is no small green circle with tick
If I highlight the second one and click set default button the small green circle moves to the second option. I can move it back to the first the same way.
If I click on the properties button it takes me to setting levels, custom, enhancements etc. there are no external speakers, only those in the laptop.
I can change the level on speakers but it makes no difference to the sound. I cna also change it on PC speaker but only from zero Db at top to a negative number. nothing I do makes any difference to the sound output. Do you need any more info?
