No Scanner Wizard on vista - help!
tigger16
Hi loved the xp scanner and camer wizard and i cant get my head around the new vista photo gallery & automatic scanner. all i want to be able to do is once i scan in a photo, is resize it to fit te page, but i cant seem to do this with vista - can anyone help me please? the xp scanner had a preview button which you could then just click to fit the screen - this is driving me mad!
What format are you saving the scanned document into?
    Dell XPS 720
    Itel Core (TM)2 Extreme CPU Q6800 @ 2.93GHz
    2 TB
    NVIDIA GeForce 9900 GTX
    Creative SB X-FI
    32" Samsung HD
    1024 x 768
    3 x 1 TB DEL Hard drives.
    Gaming
    Liquid Cooling
    Wired
    HID Keyboard
    50 Meg
erm - a jpeg image - its not giving meany options - i have just pressed same buttons on my scanner as i did before (as you can tell, not exactly technologically minded!)
Windows Photo Gallery
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
Okay. Download paint.net. You can scan images and them manipulate them. It's free, great software, and will run 64-bit if you have it. Otherwise 32-bit sw.
Paint.NET - Download
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
