No more audio!
nikolardo
I recently messed with services.msc, disabling or setting to manual a number of services that seemed to me to be ones that I did not need to start when my computer did.
However, I guess I set to manual the Windows Audio service, which disabled my audio. It will not start. I set that service, and all of them actually, to Automatic, but it still will not start. I have no audio except for the system beep when I do something I'm not allowed to.
The only reason I haven't entirely wiped Vista from my drive (I dual-boot with Ubuntu) is for a program (TrakAxPc) which I cannot get to run on Ubuntu. However, with my audio down on Vista, it's obviously pointless to try and use an audio-mixing program.
Does anyone know how I can get my audio service back up and running?
Do a system restore.
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
Hello fellow CA person!
    Home made
    Intel i7 920 Broomfield-Not overclocked
    Gigabyte X58-UD4P
    12 Gig Corsair Dominator Triple Channel 1600 DDR3
    Sapphire 3870 X2 - Just the one now
    Creative Blaster X-FI Titanium Optical to Yamaha Receiver
    Panasonic 50 inch Plasma via HDMI and used as just a Monitor
    1920x1080
    Sata Seagate 750 Gig 32MB for the Vista 64 bit and second drive is Sata 300 Gig for extra storage.
    Cooler Master 1000
    Antec 900 extra fans
    Cooler Master Hyper-N520
    MX 5000 Logitech
    MX 5000 Logitech
    Cable 12MBPS
    LG GGW-H20 Blue Ray writer running with Cyberlink Ultra 9. Home Theater system through Yamaha 7.1 Receiver connected to 11 Def Tech speakers, including powered Def Tech 15 inch sub. What can I say I like movies! Not much of a gamer.
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
Well, I suppose that's a fix, lol. Hope you have the Vista installation disk in case you ever want to install it again. If you have win7 questions, come on over to the sister site.
Windows 7 Forums
    Airbot 2.0
    ASUS Xonar D2X
    1920x1080@60hz
    Corsair HX1000W
nope, if i'd had the vista cd, i'd have just reinstalled that. but the windows 7 seems fine.
all i have to do is get my grub bootloader running again so i can get back into ubuntu
I think I know exactly what your problem is.
-Control Panel
-Hardware and Sound
-Sound
-Then click on the speakers or Audio output that you want to use
-And then in the bottom right hand corner it will say 'Set as Default'
-A small tick should then appear on the logo of the select
Play something through it after you have performed this operation.
It should work - sometimes you have to leave it for a few seconds and then it will work.
Hope this has helped
Playback Records
I'm no running windows Vista at all.
I'm running windows 7 beta now.
The audio works now because I did a complete fresh install with windows 7 beta.
