No detection of DVD drive
joypogs
Hi! I upgraded my OS to Vista premium from XP. For some months I used my DVD drive, then suddenly it stopped. My driver is TSSTcorp CD/DVD TS-L632D ATA device and I'm using HP pavilion dv6000. I tried to uninstall that driver but still no detection of the DVD drive. Please help me...
Hello joypogs! Welcome and hope you get good help here.
First open the control panel(in classic veiw) and then open administrator tools.
Open Computer Management and select the disk management option.
Once it populates see if your DVD drive is listed and check what letter is assigned. Make sure its not the same as another device on the system. If it is shown and as a dup letter, right click it and change the letter.
If it does not appeare it is probably dead and in need of replacement. But you can try things such as removeing it and re inseting it that may force windows to re detect and hopefully start it working again.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA 1 250GB Western Digital SATA 1 200GB Maxtor SATA 2x160GB Western Digitals SATA 1 320GB Seagate External 1 120GB Western Digital External 1 80GB Westen Digital External 1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
if you have reset the upper and lower filters in the registry as described by Microsoft (support.microsoft.com/kb/320553/) and you still don't get your CD or DVD not mounted try ArcSoft_Vista_Update.exe and hopefully your problem is solved.
    Acer Ferrari 1005, 1100, 4000, Quad own build
    AMD X64 Turion, Intel Quad
    3 x 4GB, 1 x 8GB
    ATI, NVIDIA
    Laptop s. o., EIZO 27''
    1280 x 800, 1920 x 1200
Taken from above mentioned article.....
Step 1: Start Registry Editor (start/run type regedit hit return)
Start Registry Editor.
Step 2: Delete the UpperFilters registry entry
  1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
  2. Expand SYSTEM, and then expand CurrentControlSet.
  3. Expand Control, and then expand Class.
  4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  6. On the Edit menu, click Delete.
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed.
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
    Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
    If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?
    The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer
Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
If you cannot access the CD or DVD drive, or if you receive an error message, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions to the problem.
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
