no audio
i cant figure out why my audio is not working. it keeps saying " no audio output device is installed" but my audio was working yesterday? i need help! does anybody know the answer?
    toshiba satellite
Is it a Laptop or a Desktop?
Have you tried to reinstall the Drivers for the Audio Device
Please see the Attachment for more information
YOU WILL NEED TO BE AN ADMINISTRATOR
Hope This Helps,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
yes it's a toshiba laptop, and i've tried installing a driver, but i am also trying to do it for free. i've tried going to my device manager to look for problems, but there is no tab to click to check on sound devices.
    toshiba satellite
Just Right click your current audio Driver and click Uninstall after that Restart your Computer then test the sound if it Doesn't work report back
Many Thanks,
Josh
    AMD HD Radeon 6870
    Novatech Night
I hope this Helps
See the attachments
Josh
    AMD HD Radeon 6870
    Novatech Night
If it asks you to Restart your Computer please do
    AMD HD Radeon 6870
    Novatech Night
this is what i pulled up, and i've already restarted my computer. still no sound. it's telling me that there's a problem but i dont know how to fix it :(
    toshiba satellite
Could you Please Reinstall that Driver and Report Back, I will be Doing some Research
    AMD HD Radeon 6870
    Novatech Night
i re-installed it and it said
This device cannot start. (Code 10)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
and also the attachment
    toshiba satellite
    AMD HD Radeon 6870
    Novatech Night
Hi
Sorry to learn your working sound driver works no more as i speak. This at times happen when you don't observe what's updating in win update centre. Am sure an update to previously installed drivers were updated as well. Try the following to see if the issue is resolved:
1. Roll back your sound drivers by selecting speaker icon in the control panel and restart your system.
If the above solve your problem not then try step 2:
2. Go to device management and Uninstall sound drivers present and restart again.
On restart your windows will detect a new device and will try to install it's drivers. If your system was working ok previously then best drivers will be selected by default. If not then restart your system and make sure you are connected to internet before a pop up to install sound driver appears. When done just select recommended option and give it time as it searches through windows update.
Hope everything will be fine otherwise realtek is tha last option though not so good with 32bit system.
    HP d530 SFF
    Intel p4 3.00ghz, 2.99ghz with Hyperthreading
    HP d530 SFF
    1 gb
    Intel i865g, 96mb
    Soundmax
    HP 1940 TFT monitor
    60hz
    Western Digital Cavier Blue 320gb IDE HD
    Compaq
    HP compaq
    HP Optical Mouse
    Techcom USB keyboard
    256kbs
What was it exactly you Did BEFORE your Sound Disappeared Because it looks like your computer cannot see your Speakers
Josh
    AMD HD Radeon 6870
    Novatech Night
i was listening to my itunes yesterday and i just closed my laptop. i re-opened it today after traveling to a friends house and the red X appeared on my speaker in the lower right hand corner
    toshiba satellite
