Newbie help
gregspappy
Hi, just purchased a new computer it has 8200 quad, 8 memory and a gt120 running vista home premium 64 bit with broadband. A few problems when I play a online game computer freezes sometimes also it keeps asking me to format a hard drive using raid. All I have is the one hard drive. How do I set up? My other slower computer plays online games great. Shouldn't this one play the games too? Thanks for any help
First thing to check is to make sure the game your playing is for a 64 bit system. Some older 32 bit on-line games can play on some 64 bit systems but not all. Why, who knows? Next, check you graphics, is it on-board graphics or do you have a separate graphics card installed. Check the settings on either of them. Most important is to check to make sure you have all the latest updates and drivers for your system. Use M$ updates from your programs list to update your important and recommended updates and check for the non essentials, you'll have to manually check the box for those to download. For your drivers, you'll have to go to the manufactures website for those which is recommended. Then reboot system. Next thing I would suggest is to run some malware, spyware, adware software, then run your antivirus then run a disk defragger and registry cleaner then reboot again. This is to rule out any bugs and tune up your system. Then check to see if your issue persists.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
