new mouse help
archie123
I Tunes hates Me
my trusted MX1000 laser mouse has up and died on me , ive narrowed it down to the logitech G5 or the razer coperhead , ive even read a review comparing the two head to head and i still cant decide .............
does anyone have either and use it for gaming? what would you recommend?
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
I personally use the G5, and I love it.
I've heard many of great things about the Razer line though.
What it really comes down to is preference, I'm quite sure both
mice will work fine for gaming.. so the issue is what you personally prefer.
Compare their specs and see which one has the most of what you deem 'important'
and go for that one.
Also the thing to keep in mind with gaming mice nowadays is mostly their 'feel'.
A 'good' gaming mouse wont do YOU any good if it doesnt sit comfortable in your palm.
IF at all possible I suggest trying them out at a computer store and compare how they feel
    Me, myself and I
    Intel Core 2 Duo E 8500
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    Asus GeForce 9800GTX+
    SoundBlaster X-Fi X-treme gamer
    Samsung Syncmaster 226BW
    1680 x 1050
    1x 250gb SATA 4x 1TB SATA in RAID5
    CoolerMaster 650Watt
    CoolerMaster 690
    4x 140mm, 3x 120mm, 1x 80mm casefans
    Logitech G5
    Razer Lycosa
    ADSL 12mbit/s
    My other OS is a Linux =)
What Ayporos said. The mouse can have all the bells and whistles going, but it isn't worth much if it is uncomfortable in the hand.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
I know , ive been gaming on the pc for 20 years ;) ;) ;) ;) I played the original Doom ;) Not with a mouse i might add :P
All jokes aside though you are of course correct :D Ive gone for the G5 mainly because of the weights (they are extra with the razer) hopefully i can get the G5 to the same weight as my current mouse , that would go along way to getting used to a new mouse , it takes me a good few weeks. Not sure if ill be using the full 2000dpi ingame but another usefull feature of the G5 is the ability to adjust the sesitivity on the fly , excellent feature , i can switch between 800dpi for general running about and spraying bullets up to 2000dpi for sniping.
Thanks for your input it seems ive made the right choice :D
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
I still think my original Logitech Mouseman Dual Optical (wired) is the best mouse ever though... and if my G5 ever breaks for some odd reason I'll just hook that back up and be a happy fragger =D
For some reason I've never been able to get my original fragging aim skills back once I switched from my dual optical to the G5 =(
    Me, myself and I
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    1680 x 1050
    CoolerMaster 690
    Logitech G5
    Razer Lycosa
    ADSL 12mbit/s
I'm using a G5 as well and I love it. I'd definitley recommend it as well. Used some Razer mice, including the Copperhead and Lachesis, and in terms of comfort, I don't think they compare to the G5 at all.
If you've been using a Logitech mouse for a while, then the G5 shape will certainly be familiar and comfy for you :)
And my aiming improved considerably when I got my G5 :p
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
Mouse, what is this mouse you speak of?
Years of KB only Wolf 3D, Heretic, Rise of the Triads and Doom made adopting the mouse a little difficult. I even played Quake with KB only for a while until I saw the light :p
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
I remember first using a mouse when playing Quake, and I remember the crosshair being all over the place while I got used to the aiming :p
    ASUS Xonar DX
    100Mbps
lol, it was a shocker to begin with wasn't it?
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
I play Team Fortress 2 and use the Logitech G9. It has DPI settings ranging from 200 to 3200. I absolutely love it. 2 Different Grips, Customizable weight and 2 scroll wheel modes. Best mouse I have owned.
I used to have a G7. Wireless Optical. Not too many bells and whistles. However, it is rechargable with 2 batteries. Would also recommend.
Extensa
    Acer Extensa 5620-6396
    Intel Core 2 Duo 5750
    4GB DDR2
    ATI Radeon HD 2400 XT
    Laptop 15.4 LCD
    1280*768
    Logitech G11 Gaming Keyboars
    ASUS Xonar DX
    100Mbps
hmmm i would just look and see what you think of the microsoft sidewinder :D
its the one i plan to get....
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
Yep ;) But now I can't stand playing anything like FPS on anything, but the PC. :p
My old bluteooth mouse was fine for desktop stuff, but poor in games so I didn't mind using the 360 controller, even on the PC.
Then I got my Lachesis.... ;)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
bah, wireless.
I know a lot of people swear by it but tbh batteries add weight and not to mention the performance of wireless mice is so-so.
When you have bad batteries and power fluctuations your pointer goes wtf
when your batteries are running low your pointer goes wtf
when there's a lot of interferrence from sender to receiver your pointer goes wtf
Ofcourse over the last few years wireless mice have become better and better but I still would never want to own one simply because in theory they CAN NOT be better than wired mice. Also I hate charging stuff =D
    Me, myself and I
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    1680 x 1050
    CoolerMaster 690
    Logitech G5
    Razer Lycosa
    ADSL 12mbit/s
I prefer a heavier mouse, hence my G5 and its weights. Keeps a steady aim.
Though I don't understand why Razer's new "gaming" mouse is wireless...
    ASUS Xonar DX
    100Mbps
well i got the G5 this morning , its a fantastic mouse when you get used to it ingame , and at its highest 2000dpi setting it takes a bit of getting used to i can tell you ;)
Its gonna take a while but i like it already , i would never beleive anyone when they aid a good mouse made them play better , but already im mor accurate with this
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
It is a great mouse. I found it to be a lot more accurate in CSS as well, especially with the weights.
Just make sure to set the rate to 1000Hz in setpoint as well for that extra few milliseconds response time ;)
And set up some DPI profiles in setpoint, too, that you can switch between. Like I have 5 settings for 650, 800, 1200, 1600 and 2000 dpi, and it's great being able to switch between them at the click of a button.
    ASUS Xonar DX
    100Mbps
^ what he said.
Ofc the 5 profiles you create is totally up to your liking. I personally use:
600 800 900 1000 1200 1500
    Me, myself and I
    Asus P5Q3 DELUXE
    4x 1GB DDR3
    1680 x 1050
    CoolerMaster 690
    Logitech G5
    Razer Lycosa
    ADSL 12mbit/s
yes guys i have all the profiles set in increments of 400 and the polling is indeed set to 100 ;) I find the highest 2000dpi setting suits me well in COD 5
my main problem is setting up the weights at the moment i have 4 x 1.7grm in each corner im trying to balance it out equally but im not sure if thats the answer , i know this is a daft question but just so i can give it a shot how do you have your weights set?
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
