You should upgrade or use an
alternative browser .
new h/d and same product key
hi,
my hard drive is going to be replaced(new old drive is defective)
when i change over and use my product key for vista will m/s accept it
homegrown
intel core2 quad Q6600 2.4ghz
gigabyte x38t-dq6
4gb ddr3 Corsair TWIN3X2048-1333C9DHX
nvidia geforce 8800gt 512mb
Realtek ALC889A codec
samsung 21.3 screen
1024 by768
500gb wd hd
250gb wd hd
Corsair CMPSU-750TX
Arctic Cooling Freezer 7 Pro
microsoft wireless mouse 7000
microsoft wireless keyboard 7000
cable 850
pioneer dvd-rw dvr215d
lite-on cd-rw sohr
creative inspire pt7800 7.1
plus 2.1 addtional speakers
hp officejet j5750
Yes it will work, as long as its the same key that came with the installation disk.
Intel Core2Duo 1.83Ghz
ATI Radeon X1300
The Contemplator
Dwarf Dwf/11/2012 r09/2013
ASRock Z77 Extreme4-M
ViewSonic VA1912w Widescreen
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
dwarf,
funny i read the other post right after i entered mine yes i copied the info just in case that became a problem
thank you
and thank you maher77
homegrown
gigabyte x38t-dq6
samsung 21.3 screen
1024 by768
500gb wd hd
250gb wd hd
Corsair CMPSU-750TX
cable 850
lite-on cd-rw sohr
hp officejet j5750
