Hey all,
Just signed up here and thought I would share the solution to this problem I have just recently figured out.
Was having a strange network problem after computer woke from hibernation; it did not happen before Service Pack 1 and never happened with XP. The problem was the internet connection would time out, partially load pages, and generally stumble & fail after resuming from sleep or hibernation. I went into Task Manager and grabbed this screenshot of the network throughput:
The green is throughput, it goes from 100% to 0%, it is apparent the computer was turning the connection "on" and "off" at regular intervals.
My network card is an Intel Pro 100/1000 built into my Abit IC7-G motherboard.
The problem was apparently the sleep mode setting on the card itself; there were no settings available for sleep mode, etc on the card using the default Vista drivers, but after installing the updated/specific drivers from Abit I was able to go into the Device Manager and there was another properties page (with Intel logo) that allowed me to disable sleep mode for the network card. That seems to have fixed it, I have not had the problem again in over a week.
Hope this helps somebody else.
