Deltasense
Hi there, I have annoying problem with my Vista laptop. I have a brother HL2040 printer which is hooked up to a Dlink router USB printer port. This works well with an old XP laptop and a couple of Macs. However the vista laptop is a pain. What happens is that I can install it fine and print to it. It works well till the computer is switched off or goes to sleep and then the printer goes offline and nothing I seem to do will fix it, short of deleteing the printer and re installing it. As you can probably imagine this is a pain every time you go to print something. Any suggestions? fixes?
