So My computer has been working fine and then two days ago I turned it on and the network connection icon wouldnt change from disconnected even though I was. Also I tried opening up the Network Sharing center but after several minutes of it not appearing I finally had to shut it down through task manager. Now, this still is occurs and if I try to just right click and repair it takes forever and then finally says there isn't anything wrong. The connection though is screwed up and no longer functions correctly. It isn't the internet or an ISP problem. I will be playing an online game and it will run smooth for a few seconds then stutter then be smooth then stutter and its the computer slowing down not the internet. I checked the four services for networking to make sure they are on and auto and they are. Also, my computer has crashed a couple times, since all this started, to blue screen saying it has had memory problems. I have 4GB of memory and there are no issues with space and or lack of cpu power, 3.0 Ghz dual core, 9800gtx+ graphics card and Asus M3N78-EMH HDMI mobo with gibabit LAN. Somehow something in Windows changed and I have no idea what or how it did. Os is Windows Vista Home Premium 64-bit. Any ideas would be appreciated. Let me know of more info would help. Thak you
- AVA Direct Custom Computers
- AMD Athlon 64 x2 Dual-Core 6000+ 3.0 Ghz
- ASUS M3N78-EMH HDMI GeForce 8200 GbLAN
- 4 GB (2x2) Kingston HyperX PC2-6400 DDR2
- eVGA e-GeForce 9800GTX+ 738 MHz 512Mb
- Sound Blaster Audigy SE
- ASUS MK221H 22" LCD
- 1600 x 1050
- Western Digital 500 GB Caviar Green, 16 MB cache, 7,200 rpm
- PSU
- Nspire 650W Modular PSU
- Case
- Coolermaster Centurion 590
- Comcast Cable 8 dl - 2 up
- Other Info
- Stock - no Overclocking
