Peacemaker
[Solved] Network adapter not found, no driver can be installed
I recently bought this rig:
Asus P5E VM HDMI (Bios 0504)
Intel E8400
Kingston 4gb
I did a clean install of Vista x64 and installed the drivers that came with the motherboard. But when I tried to install the LAN driver it said: "Installer can't find Atheros L1 ethernet controller on your system". I just can not install the driver for it because the adapter isn't found. When I look in the device manager I also can't find it and there isn't a 'network' tab. I tried manually adding hardware, but when I did hit the 'have disk' option and select the driver .inf file it asked to select the network adapter from the list, but that list was empty.
What I tried:
- Reinstall Vista
- Downloaded the newest driver from the Asus website for this mobo
- Disable and enable the 'onboard LAN' option within the BIOS
Nothing worked. I also used Everest hardware tracking tool to look for the network adapter but it couldn't find it.
Does anybody know any solution or can anybody explain the problem? Is the motherboard broken??
I could try updating the BIOS to the newest version but that might hurt my warranty?
Intel E8400
Kingston 4gb
What I tried:
- Reinstall Vista
