Need to upgrade VGA card
fourlambs
Hello,
I have recently upgraded from XP SP2 to VISTA 32.
Both Vista DVD Maker and AERO are not funtional and Vista tells me its due to using a NVIDIA Geforce4 MX4000 graphics card, so I need to replace it...
Not knowing too much about this sort of stuff, I have found a AGP FX5500 in a local store and I wonder if it would be OK ? Or should I go for something with a little more 'grunt'?
The PC is used mainly for photo editing and burning video to DVD, very little gaming, attached are my specs.
All help appreciated.
Phil
Pardon my ignorance but does your motherboard have AGP, PCI or PCI-E. It will basically depend on that outcome.
If it's a PCI-E, then i have a BFG 8800 GT and thats great and will deffiantly furfill your requirments.
What sort of price range are you willing to go to.
    Intel dual core @ 2.8GHz
    2GB DDR-2
    BFG 8800GT ocx
    Nil
    22" Xerox
    1600x1200
    1x 150GB sata 1x 200GB IDE 1x 1TB External
    JeanTech 700W
    Nil
    Nil
    Razer DiamondBack with Razer eXactmat
    10mb (virgin)
    Need new RAM and CPU :\
My motherboard is around 4 years old and is a Gigabyte Socket A Motherboard GA-7S748 series and AGP.
The two VGA cards I can get locally, without drivering an hour to the city are:
AGP XFX 6200 or an AGP FX 5500
I know little about either of them.. !
Thanks
Phil
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Hey mate, thanks for the info, ive done a little research for you.
Below are links to very reputable companys in the UK, please read the reviews they are very handy.
AGP XFX 6200
Innovision GeForce 6200 256MB DDR2 64Bit AGP Graphics Card - Ebuyer
AGP FX 5500
Gainward 5500 256MB VGA DVI TV Out AGP Graphics Card - Ebuyer
Both have ok ratings, and are not really ideal for gaming, thou they can play games like Half life 2 and Counter strike: source on Mid settings.
They sound fine for your usage, thou personally I'd save up a little and perhaps buy:
Sapphire RADEON X1650 PRO 512 MB
Sapphire X1650Pro 512MB DDR2 VGA DVI TV Out AGP Graphics Card - Ebuyer
It has a better core clock speed but slightly more expensive, but unfortuantly im not 100% on how much your willing to spend etc so read the reviews on those other two cards and see how it goes.
Sorry if the above cant help.
    2GB DDR-2
    BFG 8800GT ocx
    Nil
    22" Xerox
    1600x1200
    JeanTech 700W
    Nil
    Nil
    10mb (virgin)
The 6200 wil be absolutely fine :D
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
