passnthru2
my Vista64 problems have worn me out, i need to have access to an XP program due to incompatible hardware problems/software, such as i need to use voice recognition Dragon10 and they will be a while to upgrade to v64.
i want to get a bigger HD, 1 Tb, put XP on it, and later when Vista64 problems are resolved, i can put my Vista on as a dual boot on the new big HD, i hear it is better to ad Vista to XP.
there are just too many things i need to do that are not compatible with Vista64
i need to do this as simply as possible, like changing the 2 HD's in the BIO's if necessary if i cant easly dual boot, i can not afford to crash the Vista, which i hear can happen with setting up a dual boot on the same HD, if one is not knoledgable about the technical details.. i am not.
my other question is if i will run into a lot of problems if i use XP64, i have 8 Gig of RAM. i need to run Dragon10 voice recognition.. takes a full Gig. and I'd like to play competition Multiplayer games..i have a 1Gig GPU, but i will settle for XP32 to avoid problems, that is why i parking the Vista to begin with as the particular games i am playing now have some problems with some people's Vista.. like mine. i have a home built computer, that may be it. i may just have to take it to the shop.. which i'd rather not do.
i am not familiar with the details of tweaking things in the Matrix, i build Avionics control circuit boards for the F22 and the Delta3 Rocket.. but i dont mess with their programs. I'm just learning this part of it, and the learning curve is really steep.
if anyone has some links they know of that would help me out, i appreciate the info
- Intel e8400 3MHz Core2 Duo
- ASUS Rampage Formula X48
- 8GB OCZ Reaper HPC DDR2 1400
- VisionTec Radeon HD 3870 1 Gb
- 2x Western Digital Caviar 500GB HD RAID1
- PSU
- Cosair 750 watt PSU
- Case
- ANTEC 900
- Cooling
- Silent Knight2 CPU cooler
- Other Info
- OPTI UPS Battery Back Up
