Need some help with my computer
tlbs
Ok, so I have Vista Home Premium 32 bit, and an HP Pavilion dv6000 laptop. my recently shattered my screen, and am currently using a monitor until my screen arrives in the mail. A few weeks ago, I was just messing around, and accidentally change the monitor settings to split screen. I waited about a minute, cause windows usually has that do you like these settings or whatever, and nothing happened. I tried doing a system restore, two to be exact. Didn't fix it. I've been running safe mode for the past 2 weeks or so, and want to do something about it, anyone know how to fix it?
    HP Pavilion DV6000
    AMD Turion X2 Dual Core
    n/a
    3GB
    nVidia
    n/a
    15" Touch-Screen
    600x800/1280x780
    250GB internal(1) Toshiba 160GB External(1)
You have to go into the display settings in Control Panel or right click on an empty area on the desktop to look in the display manager to see if more then one monitor is set. It appears that both desktops were moved onto the external monitor somehow.
That will pose another problem however since you have no default display without the laptop's screen until the replacement comes in. If you try to correct this now without that you may end up without anything being displayed on the monitor.
    Custom built desktops =2 Toshiba replace HP laptop
    AMD Phenom II X4 975 Deneb core 3.6ghz
    Gigabyte GA-790XTA-UD4
    Kingston Hyper X 1.5v DDR3 PC12800 1600mhz 16gb
    MSI Radeon HD 5750 1tb
    Creative X-Fi XtremeAudio PCIe
    Asus 19" HP 20" second lcd main HP 20" remote pc.
    1440x900, 1600x900 main - 1600x900 2nd desktop
    WD Black Edition 1tb Sata II -2 WD SAS "Heavy Duty" RE class 2tb - 2 External usb/eSata WD Black 1tb main -1 External usb only WD Green Power 1tb -1
    Corsair 750w 750TX main - Corsair 600w remote
    Antec 900-2 - SSD compatible eSata ports 2 - NZXT Vulcan 2nd
    Zalman CNPS9900A cpu, twin front 120s, top 200cm, rear 120
    MSI Interceptor D200
    AZIO Ilumminated keys gaming keyboard/volume control usb
    30mbps upgrade
It was something in the control panel. Like MobileMe or something.
    HP Pavilion DV6000
    n/a
    3GB
    nVidia
    n/a
    15" Touch-Screen
    600x800/1280x780
Mobileme is how Applie manages email and other things at me.com. The general information is seen at Apple - MobileMe
Since that line of laptops uses the GeForce Go 6150 the display manager in control panel or at the top of the menu when right clicking on the desktop. But none of that should be seen while booted in safe mode unless there's a separate screen setup menu for the laptop itself much like the button seen along the edge of dosplay's frame.
    30mbps upgrade
