Tomorrow im getting all the stuff for building my new PC, i have some questions that hopefully you can help me with
I read the tutorial on installing vista (been looking for that for ages btw!:D)
Right anyway, im getting sp1 on a seperate disc with my new stuff. Should i install Vista, then drivers (can anyone help me with this too), and then insert the SP1 disc?
Or is there a better way to do it, as this will be from a completly clean HDD, unformatted etc..
Cheers in advance, your help will be greatly recieved.
- AMD AM2 Athlon 64 X2 6000+
- MSI K9A2 Platinum
- 2GB (2x1GB) Matched Corsair DDR2 Memory 800
- Sapphire Radeon 4870 512MB
- On Board (Upgrade soon)
- 17" :Hansol CRT Monitor
- 1024x768
- 500GB Western Digital Caviar 7200rpm
- PSU
- Corsair TX750W
- Case
- Antec 900
- Cooling
- 3x120mm Case fans, 1x200mm Exhaust Fan, Stock CPU Cooler
- Genius Netscroll+Eye Ruby
- IBM KB-9910
- Up to 16mb usually around 6-8MB
- Other Info
- CPU Temp at almost full load was around 36oC, Graphics Card rarely goes above 58oC
