Need permission to drag and drop...
Steel Rat
Hello All,
I've been googling this issue and can't seem to get the right search phrase going, or I'm the only one experiencing this issue.
The problem: Cannot drag and drop folders if the folder tree being dragged is 3 or more folders deep.
I get the error dialog: "You need permission to perform this action", with a "Try Again" and "Cancel" button.
I can drag folders out of the tree with no problem as long as the tree is less than 3 deep. Example:
Folder1
__|___Folder2
____|___Folder3
I cannot drag Folder1 anywhere, but can drag Folder2 or Folder3 without a problem, and then I can drag Folder1 when the children are gone, or the depth is reduced to two.
I've tried the "Take Ownership" and "Modify Permissions" tutorials, but the problem persists. None of the folders are virtual or shortcuts.
Any ideas?
Thanks!
