Need Help
honkey1122
There are icons infront of the real icons and i have no clue how to get rif of them i downloaded aliengiuse from alienware to change everything but this was the biggest mistake as you can see .Hope someone can help greetings from germany!
    IntelCore2Quad CPU Q6600 @2.40GHz 2.40GHz
    3GB
    Nvidia 8600GT
    19''widescreen Medion
    1400*900
    500GB Intern 500GB USB 320GB USB 145GB USB
    Medion
    16000-DSL
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
hey thanks ill give that i try
    3GB
    Nvidia 8600GT
    1400*900
    Medion
    16000-DSL
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Does this happen on new shortcuts or just the ones you have had before the program?
Have you tried a system restore?
If looks as if the program is trying to create a thumnale of the document etc of the icons.
Does this just happen on the desktop?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
ive tried system recovery and the above postet^^^ but nothing worked so far the only thing i can think of now is rebooting the whole system to nothing but thats what i dindnt want to do
This problem isnt only on the desktop as seen here.
    3GB
    Nvidia 8600GT
    1400*900
    Medion
    16000-DSL
just another example as you can see it seems like something is simply missing
Ive experince a break through you could say i downloaded the newest geforce drivers and now some icons are back to normal but still not everything im just getting frustsrtaded
sry for my english its been a while :)
    3GB
    Nvidia 8600GT
    1400*900
    Medion
    16000-DSL
okay i finaly solved the problem with vista visual master in about 3 sec. thanks for your help anyway;)
    3GB
    Nvidia 8600GT
    1400*900
    Medion
    16000-DSL
