Need help
tg1010
Okay, I am using excel and trying to find out the probability of a number from column G2 and divide it by 36 to get a decimal (being the probability). [ =G2/36]
However, when I use the CORRECT equasion, all it does is give me a random date!! It says 'Jan-00'.
I have NO idea what to do and i really need help fast; it's for a project.
Thanks
This should probably go in the software board....
Anyways, using Excel 03, or 07??
Could be a difference
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
OK, unfortunately I have almost no expirience with that version (I am a stickler for '03 even though my school switched to '07 and I hate it)
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
The results are probably how you want them, but the format is incorrect. Right-click the cell containing the formula, then pick "Format Cells", then change your number format to General.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
