need help with usb devices
Konvikt
Hi, i have a problem with my usb ports, ok so like last week i got my computer back from the manufacturer, i accidently knocked it over, (but we didnt tell them that).
but anyways, i installed itunes, and tried to plug in my ipod, this was the first usb device i plugged it since i got it back, and for some reason it worked fine for like 10 minutes, then automatically disconnected, then reconnected, and reapetedly keeps doing that whenever i try to plug in a usb device. i did not have this problem before i sent it to get repaired, and now i do. if anyone can help, it would be much appreciated. and im on home premium sp1 32bit if that has anything to do with it
thnx again
Hi, Konvikt, and welcome to the forums.
I'd call them right back up and tell them this is happening.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Honestly? I wouldn't bother for one second. Who knows what problems you may have down the line with the USB subsystem, - get them to look at it now while you're under some sort of a warranty.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
Are you connected to onboard USB ports or front panel ports when the issue is occuring? Have you tried different USB ports on the unit, does it do the same thing for all of them?
both of the usb ports on the front do it, im not sure about the back ones
*Update* ok i trued my ipod in the back, and it works, also i started up crysis and hooked up a 360 controller to the FRONT and it worked fine
