Need Help With Some Services
Elite Knight
ANIME MAD!!!
Ok i'l make it short and simple.
How do you turn off mobsync it makes my pc lose smoth performance. And tryed offline files and it still comes on.
Wireless.
As in XP you had wireless zero config and turned it off and make my games not lag. But in vista it shuts down your internet when you shut it off. I want to stop the lag spikes while i play games.
And yes i know wireless isent for gaming but we have a dosen pc's here and dont have a finance to have cords all over the place it's a 2 story home with 8 pc's and 4 laptops so i just want a way to stop the wireless from resetting every 60 seconds. Make it every 6 hours if i can.
Thanks for replaying.
    NEC PowerMate V7330
    Intel Quad Core Q9650 3.0ghz
    Gigabyte
    4GB DDr2 800Mhz
    Nvidia Geforce GTX260 1GB Edition
    Sound Blaster 7.1 High Def Audio
    AOC 193Fw
    1440X900
    5X 1GB Seagate 32MB Cache 7200.12rpm
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
Sorry for dobble posting but im a huge gamer and i really need help.
    NEC PowerMate V7330
    Gigabyte
    4GB DDr2 800Mhz
    AOC 193Fw
    1440X900
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
Hi Elite Knight,
the problem that you have is caused by differences between XP and Vista in the handling of Wireless connections
Did find this on another site ...
To disable the WLAN Autoconfig you can follow these steps:
- Click on Start, type in "cmd" without the quotes, then right-click on cmd.exe which appears in your search.
- Select run as administrator.
- The WLAN service must be running first. If it isn't type net start wlansvc.
- Type in netsh wlan set autoconfig enabled=no interface="name of your wireless network here" (with the quotes)
- If you need to see the name of your wireless network first, type in netsh wlan show settings
That will disable the WLAN Autoconfig
Please be aware I have not tried this so make sure you know the original settings before you change things
Original post ...
Lag every 60 Seconds Exactly - Wireless - Networking
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
Yea i did and i dont get there. Heres a error. There is no such wireless interface on the system.
    NEC PowerMate V7330
    Gigabyte
    4GB DDr2 800Mhz
    AOC 193Fw
    1440X900
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
Hi, to have the "run as admin" option when you enter CMD into the search bar the CMD.exe file will appear in the list above the bar - Right click on theis entry and select the run as admin option or if the CMD.EXE entry is the only entry in the list press CTRL-SHIFT-ENTER
The cmd box will appear with the word Administrator in the title bar
Note - You have to be loggied in as an administrator to acess this functionality
hope this helps ...
Edit
check the details in the "netsh wlan show settings" and make sure you enter the name exactly.
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
I might try a tool called Vista Anti Lag. Does it work. And no it dident work i will try admin laters after my download of the PMI thing.
    NEC PowerMate V7330
    Gigabyte
    4GB DDr2 800Mhz
    AOC 193Fw
    1440X900
    650Wat
    V9 Case
    300mm Fan
    G5 Logitech
    NEC Keyboard
    24000/19000 ADSL +2
    I like this PC.
