Need help with paths in XP and Vista.
Skyzoomer
I'm writing a batch file which calls a 32 bit .exe program. I want it to be compatible with the different Windows operating systems. The problem is that the path to "Program Files" is different depending which OS is being used. For instance:
I know the paths for these OS' since I use them:
- WinXP 32 bit: C:\Program Files\
- Vista 64 bit: C:\Program Files (x86)\
Could some kind souls please tell me what the 32bit paths are for:
- WinXP 64 bit:
- Vista 32 bit:
And for Windows 7 also would be nice:
- Win7 32 bit:
- Win7 64 bit:
Thanks!
Sky
Environment variable - Wikipedia, the free encyclopedia
Look down in the section called "system path variable" for %ProgramFiles%.
Some other good stuff on that page as well.:D
Gil
Hi Gil,
Thanks for that nice link. Very informative.
Unfortunately the %ProgramFiles% variable did not work for me. Here's a sample of both paths I used in my batch file on my WinXP PC:
"C:\Program Files\ImgBurn\ImgBurn" ........ <= This works fine.
"C:\%ProgramFiles%\ImgBurn\ImgBurn" .... <= This fails.
Any ideas?
EDIT: Reading your link in more detail, my problem is to determine whether a 32bit or 64bit version OS is running, not whether it is XP or Vista. Apparently 32bit XP or Vista uses \Program Files\ and 64bit XP or Vista uses \Program Files (x86)\.
I'll have to google how to determine whether 32bit or 64bit for my batch file.
Thanks!
Leave the quotes off.. Call it thusly:
Try that.
Gil
Gil
Hi Gil,
Any ideas?
    Dell Inspiron Notebook
    2.5 Mbit/s
Try that.
Gil
Yes, after finally understanding that the %ProgramFiles% is just a shortcut for "C:\Program Files" (without the quotes), I can see how your suggestion can work.
But there is also a %ProgramFiles(x86)% variable for 64bit systems.
It would have been ideal if %ProgramFiles% automatically handled 32 or 64 bit systems and just inserted the correct path. But it evidently still remains the user's task to determine 32 or 64 bit and use the correct variable.
Thanks a lot for your help. I've learned quite a bit and what I need to do now because of it.
Sky
I'm not sure about XP 64 bit but in Vista, and I assume Windows Seven, 64 bit versions, if it is 64 bit, this file exists:
%windir%\syswow64\explorer.exe
which should usually expand to
c:\windows\syswow64\explorer.exe
That's the 32 bit shell. In fact if you check the tutorials there's one of mine to create a shortcut to open the 32 bit explorer on 64 bit Vista. Some 32 bit program's shell extensions will work if you open Explorer using that copy of explorer.exe(see HalfShell in free programs for Vista list for more info.)
If you are on a 32 bit system that "syswow64" folder won't exist.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Thanks!
Sky
