need help with my graphic card
moore
i have a mobile intel (r)965 express chipset family graphic card/driver. is it possible to upgrade to nvidia? can any1 help me update my graphic card to nvidia step by step?
Need your laptop make and model.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
I believe that you can't upgrade the graphics because its part of the motherboard.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
not on a laptop as they are built around the motherboard if you did try to change it then the cpu fan might be in the wrong place the harddrive might not mount in it's slot and the dvd drive would probably not be able to attach to the mobo the only way would be to buy a new laptop with an nvidia card.
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
