Need help with Fatal1ty Headset
fatal1ty
Alright, I got the fatal1ty headset and I'm having a problem with my MIC. The headphones are working perfectly. It's recognizing the headset but no sound is coming out when I speak, seems like it's on mute, on the headset the mic is set on "on."
    HP-Pavilion
    Intel Core Quad CPU Q6600 @ 2.40GHz
    Pheonix - AwardBIOS v 6.00PG
    3072MB
    NVIDIA GeForce 8800 GTX
    High Definition Audio Device
    HP w2207 22'
    Seagate Barracuda 7200.10 Hard Drive - 320GB - 7200rpm - 300MBps Serial ATA - II - Serial ATA/300 - Serial ATA - Internal - ST3320820AS Seagate Barracuda 7200.10 Hard Drive - 320GB - 7200rpm - 300MBps Serial ATA - II - Serial ATA/300 - Serial ATA
    MX 518
    Eclipse 2
    3MB
are you trying to get the sound through the speakers?, you would need to enable the stereo mix for that, right click the recording devices menu, and select show disabled devices, right click stereo mix and enable:
This should give you mic output through speakers, but it proves to be more annoying than having it off, to test your mic, simply open up the sound recorder and record yourself talking into the mic, play it back and if you heard yourself then the mic works. (make sure your microphone is set to the default device ;))
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
No, I'm just trying to get my mic to work. The other thread is for jacks, my headset is a USB. I don't want my MIC sound to come out from my speakers, and I have tried recording myself and no sound...
    HP-Pavilion
    3072MB
    HP w2207 22'
    MX 518
    Eclipse 2
    3MB
Hey fatality
Could you do us a favor and fill in your system specs (lower left corner) so we know what kind of hardware you have.
Thanks in Advance
Ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Alright, doing it right now.
    HP-Pavilion
    3072MB
    HP w2207 22'
    MX 518
    Eclipse 2
    3MB
Nice system. In your audio cpanel do you have an adjustment for what goes to each jack? Could you use the snipping tool (type snip in search) and take a screenshot of your audio control panel?
Thanks
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Thanks
Ken
Thank You. Actually, seems like I have fixed the problem, on my headset, I didn't push the MIC deep inside, it's working now, but I still have another issue, I could hear myself through my headset and it's annoying, any way to turn it off?
NVM I FOUND OUT HOW TO FIX IT. I WENT IN THE PROPERTIES AND THERE WAS "LISTEN TO THIS DEVICE" CHECKED AND I UNCHECKED IT, WHICH FIXED THE PROBLEM.
    HP-Pavilion
    3072MB
    HP w2207 22'
    MX 518
    Eclipse 2
    3MB
gald you are working
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
