Need help removing totally virus security suite
The weekend before last I was hit with this Security Suite virus which took over my computer. I may have had it for a little while because I did notice that suddenly I had a scan of Windows products done. Then Word 2007 suddenly showed up which I never loaded on my machine. Then when my McAfee gave me the notice it was time to renew that's when my machine became disabled. After realizing I couldn't go into control panel, go online etc I found instructions on bleeping computer.com to remove this and use malwarebytes by going into Safe Mode I was able to run the Malwarebytes and get back online. But here are the symptoms still occurring:
1. IE will not launch
2. There's a shortcut program on bottom right trying to launch that is being blocked right now but that means I still have residual files on my machine.
3. I cannot stop several tasks in Task Mgr, they are blocked and Users are not identified.
Can you help me go through the steps to get rid of the hidden files left on machine?
I have run several scans both quick and long but nothing is showing so the Malwarebytes appears to no longer be effective or this virus is back. Also I did copy some Documents onto some Flash drives during this and I want to make sure that those are parasite/virus free before putting those back on this machine.
Thank you
There are several different methods on this forum to use but I am not sure which direction now to take after having gone through the manual for removal that was posted on bleeping computer.com and running malwarebytes. Is there someone here that can help me?
Thanks
Hello belleartiste and welcome to the forums :party:
Do you know how you got the virus? And do you have a Vista installation disc?
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
I am not sure how I got the virus. I did notice that a month or so before all this happened I did receive a message that a scan wanted to check for current windows office products on my system. Then eventhough I didn't have any win office 07 products suddenly Word 07 showed up. So I thought well maybe I received an temporary update or something. I am a designer so I didn't really get overly concerned thinking well I had McAfee on my system. Generally I try to be careful web surfing etc. But apparently this virus slipped through.
When I bought my HP laptop it already had the Vista Home Edition on it. The disk that I have with Vista is labeled update.
Several IT people and other sources have recommended all sorts of options to get rid of this virus entirely. One person said to do a system restore back to several months before you think you may have received this virus. But I do not know whether this virus would still have infiltrated my files still. I just don't know which direction to take. Plus my design files that I copied to my flash drives, could those be infected too? Those are only My Document files like .jpg and docs .html files. The other problem is that I had McAfee on three machines, two laptops and a desktop. The desktop I think is virus free, just runs a bit slow but it's a little older like 4 yrs. The other laptop I ran Malwarebytes it found two items but nothing bad, had those removed. So not sure what to do at this point.
Thank you
Well first of all I want you to boot into safe mode:
Boot into safe mode:
1. Save any work and close all open windows
2. Press Alt+F4
3. Select Restart in the drop down menu and press ok
4. When your computer has shutdown and is just starting to boot again (on the BIOS screen that usually has the manufacturer’s logo on it) press F8
5. Using the arrow keys, select Safe Mode and press enter
Then I want you to run a SFC scan, 3 times:
SFC Scan:
1. Open the start menu
2. In the search box, type cmd
3. Right click on command prompt and select Run as administrator
4. In command prompt, type:
sfc /scannow
5. Let it run and let me know if it finds any Integrity Violations
Then I want you to download the AVG rescue CD and burn it to a CD:
http://www.avg.com/us-en/avg-rescue-cd
Here is a guide of how to use it:
AVG Free - AVG Rescue CD Guide
I want you to run a scan, and delete any detected items.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Hi belleartiste, if you're still with us ...
Let's flush your DNS cache and repair MS's Hosts file
Copy and paste these lines in Note pad.
@Echo on
pushd\windows\system32\drivers\etc
attrib -h -s -r hosts
echo 127.0.0.1 localhost>HOSTS
attrib +r +h +s hosts
popd
ipconfig /release
ipconfig /renew
ipconfig /flushdns
netsh winsock reset all
netsh int ip reset all
shutdown -r -t 1
del %0
Save as flush.bat to your desktop. Right click and run as Administrator. Your computer will reboot itself.
Next,
download DDS from one of these links:
Mirror 1 Mirror 2 Mirror 3
  • Disable any script blocking protection
  • Double click the dds icon to run the tool.
  • When done, DDS will open two (2) logs:
    1. DDS.txt
    2. Attach.txt <---this will be minimized in the task tray
  • Save both reports to your desktop.
Include the contents of both logs in your next post.
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device. One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
Belleartiste, I think that it is better if you get your help of Jacee now, because she is far more experienced than me at virus removal.
Thanks,
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Jacee,
I followed the steps you gave me. First I ran the flush.bat file and then downloaded the DDS. Here are the logs. I really appreciate your assistance. Let me know what you discover and what my next steps should be.
Thank you
Belongs to this application Photo Card Event Planner Reminder.lnk
c:\windows\installer\{c885990f-a824-41a1-82fb-61e3859b4ce2}\Shortcut_Event_Pla_C885990FA82441A182FB61E3859B4CE2.exe
Do you recognize downloading this?
Are you still unable to open IE?
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
I do recognize the application Photo Card.
IE still will not open. It will initially try to open and then it just closes right away.
A couple other things I noticed is that I believe when I purchased my HP it had a trial of win office 2007 but I loaded my Office 2000 instead. However, on the Attach file there's all these security update files listed for Win office 2007 products. I do remember that shortly before my computer was hit with this virus it did do a check to see if my win office products were current. So I am not sure if those are unusual files or not. I just wanted to mention that.
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
Good for you! Now let's empty all temp folders ...
Please download TFC by Old Timer TFC - Temp File Cleaner by OldTimer - Geeks to Go Forums and save it to your desktop.
Save any unsaved work. TFC will close ALL open programs including your browser! Right-click on the TFC.exe file and choose Run As Administrator.
Click the Start button to begin the cleaning process and let it run uninterrupted to completion.
Important! If TFC prompts you to reboot, please do so immediately. If not prompted, manually reboot the machine anyway to ensure a complete clean.
TFC (Temp File Cleaner) will clear out all temp folders for all user accounts (temp, IE temp, java, FF, Opera, Chrome, Safari), including Administrator, All Users, LocalService, NetworkService, and any other accounts in the user folder. It also cleans out the %systemroot%\temp folder and checks for .tmp files in the %systemdrive% root folder, %systemroot%, and the system32 folder (both 32bit and 64bit on 64bit OSs). It shows the amount removed for each location found (in bytes) and the total removed (in MB). Before running, it will stop Explorer and all other running apps. When finished, if a reboot is required the user must reboot to finish clearing any in-use temp files.
TFC only cleans temp folders. TFC will not clean URL history, prefetch, or cookies. Depending on how often someone cleans their temp folders, their system hardware, and how many accounts are present, it can take anywhere from a few seconds to a minute or more. TFC will completely clear all temp files where other temp file cleaners may fail. TFC requires a reboot immediately after running. Be sure to save any unsaved work before running TFC.
When you have rebooted,
I'd like you to scan your machine with ESET OnlineScan
  1. Hold down Control and click on the following link to open ESET OnlineScan in a new window.
    ESET OnlineScan
  2. Click the
    button.
  3. For alternate browsers only: (Microsoft Internet Explorer users can skip these steps)
    1. Click on
      to download the ESET Smart Installer. Save it to your desktop.
    2. Double click on the
      icon on your desktop.
  4. Check
  5. Click the
    button.
  6. Accept any security warnings from your browser.
  7. Check
  8. Push the Start button.
  9. ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
  10. When the scan completes, push
  11. Push
    , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
  12. Push the
    button.
  13. Push
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
The scan just finished and it says no threats found. Took over 2hr and 20min to complete. So there's nothing to save. The only options are to cick finish and uninstall on close. I only clicked Finish.
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
I downloaded Secunia's PSI. Before I set a new restore point I did have a question. How do I remove or stop one of the programs from trying to launch from the quick launch area on the bottom right of my screen? There is one program that my system seems to be still blocking after I start it up. Would this be at all related still to the previous virus my machine had or is that related to something else?
One other question I have been using McAfee but after having my machine get hit so hard by that virus before I was wondering if there was a better product(s) to use?
Thank you.
Download HijackThis!
HijackThis - Trend Micro USA
Right click on HJT to run as Administrator.
Click 'Do a System Scan and Save logfile'.
The HJT log will open in notepad.
Copy and paste the HJT log from notepad in your next reply.
    INTEL/D975XBX2
    1280 x 1024
    Rocketfish 700 W
    DSL
    ATI HDMI Audio
Here's the HJT log:
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 12:15:38 PM, on 10/4/2010
Platform: Windows Vista SP2 (WinNT 6.00.1906)
MSIE: Internet Explorer v8.00 (8.00.6001.18943)
Boot mode: Normal
Running processes:
C:\Windows\system32\Dwm.exe
C:\Windows\Explorer.EXE
C:\Windows\system32\taskeng.exe
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\Program Files\HP\QuickPlay\QPService.exe
C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QLBCTRL.exe
C:\Program Files\Common Files\Java\Java Update\jusched.exe
C:\Program Files\Lexmark 2400 Series\lxcrmon.exe
C:\Program Files\Lexmark 2400 Series\ezprint.exe
C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe
C:\Program Files\HP\HP Software Update\hpwuSchd2.exe
C:\Windows\vsnp2uvc.exe
C:\Program Files\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe
C:\Windows\System32\atwtusb.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\Program Files\SweetIM\Messenger\SweetIM.exe
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
C:\Windows\System32\rundll32.exe
C:\Program Files\Windows Sidebar\sidebar.exe
C:\Program Files\Windows Media Player\wmpnscfg.exe
C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe
C:\Program Files\HP Connections\6811507\Program\HP Connections.exe
C:\Program Files\Hallmark\Hallmark Card Studio Photo Card Edition\Planner\PLNRnote.exe
C:\Program Files\Yahoo!\Yahoo! Music Jukebox\ymetray.exe
C:\Program Files\Hewlett-Packard\HP wireless Assistant\WiFiMsg.EXE
C:\Program Files\Secunia\PSI\psi.exe
C:\Program Files\Hewlett-Packard\Shared\HpqToaster.exe
C:\Program Files\Yahoo!\Messenger\ymsgr_tray.exe
C:\Program Files\Common Files\Java\Java Update\jucheck.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Windows\system32\Macromed\Flash\FlashUtil10i_ActiveX.exe
C:\Windows\system32\SearchFilterHost.exe
C:\Users\Cindy\Desktop\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = Preserve
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = Yahoo!
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = Yahoo!
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = AOL.com - Welcome to AOL
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = Yahoo!
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = Yahoo! SearchBar Home Page
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = Yahoo!
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = AOL.com - Welcome to AOL
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = %s - Yahoo! Search Results
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=127.0.0.1:6092
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\PROGRA~1\Yahoo!\Companion\Installs\cpn1\yt.dll
O3 - Toolbar: Lexmark Toolbar - {1017A80C-6F09-4548-A84D-EDD6AC9525F0} - C:\Program Files\Lexmark Toolbar\toolband.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: SweetIM Toolbar for Internet Explorer - {EEE6C35B-6118-11DC-9C72-001320C79847} - C:\Program Files\SweetIM\Toolbars\Internet Explorer\mgToolbarIE.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
O4 - HKLM\..\Run: [Windows Defender] %ProgramFiles%\Windows Defender\MSASCui.exe -hide
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [QPService] "C:\Program Files\HP\QuickPlay\QPService.exe"
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [lxcrmon.exe] "C:\Program Files\Lexmark 2400 Series\lxcrmon.exe"
O4 - HKLM\..\Run: [EzPrint] "C:\Program Files\Lexmark 2400 Series\ezprint.exe"
O4 - HKLM\..\Run: [FaxCenterServer] "C:\Program Files\Lexmark Fax Solutions\fm3032.exe" /s
O4 - HKLM\..\Run: [LXCRCATS] rundll32 C:\Windows\system32\spool\DRIVERS\W32X86\3\LXCRtime.dll,_RunDLLEntry@16
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 8.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [YSearchProtection] "C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe"
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\Hp\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [snp2uvc] C:\Windows\vsnp2uvc.exe
O4 - HKLM\..\Run: [HP Health Check Scheduler] c:\Program Files\Hewlett-Packard\HP Health Check\HPHC_Scheduler.exe
O4 - HKLM\..\Run: [BlackBerryAutoUpdate] C:\Program Files\Common Files\Research In Motion\Auto Update\RIMAutoUpdate.exe /background
O4 - HKLM\..\Run: [atwtusb] atwtusb.exe beta
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
O4 - HKLM\..\Run: [SweetIM] C:\Program Files\SweetIM\Messenger\SweetIM.exe
O4 - HKLM\..\Run: [mcui_exe] "C:\Program Files\McAfee.com\Agent\mcagent.exe" /runkey
O4 - HKLM\..\Run: [NvSvc] RUNDLL32.EXE C:\Windows\system32\nvsvc.dll,nvsvcStart
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\Windows\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\Windows\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [hpWirelessAssistant] C:\Program Files\Hewlett-Packard\HP Wireless Assistant\HPWAMain.exe
O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
O4 - HKLM\..\RunOnce: [Launcher] %WINDIR%\SMINST\launcher.exe
O4 - HKCU\..\Run: [Sidebar] C:\Program Files\Windows Sidebar\sidebar.exe /autoRun
O4 - HKCU\..\Run: [HPAdvisor] C:\Program Files\Hewlett-Packard\HP Advisor\HPAdvisor.exe
O4 - HKCU\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter
O4 - HKCU\..\Run: [Yahoo! Pager] ~"C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" -quiet
O4 - HKCU\..\Run: [YSearchProtection] C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe
O4 - HKCU\..\Run: [Search Protection] C:\Program Files\Yahoo!\Search Protection\SearchProtection.exe
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKCU\..\Run: [ISUSPM] "C:\Program Files\Common Files\InstallShield\UpdateService\ISUSPM.exe" -scheduler
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - Global Startup: Adobe Gamma Loader.exe.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: HP Connections.lnk = C:\Program Files\HP Connections\6811507\Program\HP Connections.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O4 - Global Startup: Photo Card Event Planner Reminder.lnk = ?
O4 - Global Startup: ymetray.lnk = C:\Program Files\Yahoo!\Yahoo! Music Jukebox\ymetray.exe
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O16 - DPF: {7530BFB8-7293-4D34-9923-61A11451AFC5} (OnlineScanner Control) - http://download.eset.com/special/eos/OnlineScanner.cab
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - http://platformdl.adobe.com/NOS/getPlusPlus/1.6/gp.cab
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\Windows\system32\browseui.dll
O23 - Service: AddFiltr - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\AddFiltr.exe
O23 - Service: CyberLink Background Capture Service (CBCS) (CLCapSvc) - Unknown owner - C:\Program Files\HP\QuickPlay\Kernel\TV\CLCapSvc.exe
O23 - Service: CyberLink Task Scheduler (CTS) (CLSched) - Unknown owner - C:\Program Files\HP\QuickPlay\Kernel\TV\CLSched.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: HP Health Check Service - Hewlett-Packard - c:\Program Files\Hewlett-Packard\HP Health Check\hphc_service.exe
O23 - Service: hpqwmiex - Hewlett-Packard Development Company, L.P. - C:\Program Files\Hewlett-Packard\Shared\hpqwmiex.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Roxio\Roxio MyDVD Basic v9\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: lxcr_device - - C:\Windows\system32\lxcrcoms.exe
O23 - Service: McAfee SiteAdvisor Service - Unknown owner - C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Personal Firewall Service (McMPFSvc) - McAfee, Inc. - C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee VirusScan Announcer (McNaiAnn) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\Program Files\McAfee\VirusScan\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\McSvcHost\McSvHost.exe
O23 - Service: McShield - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mcshield.exe
O23 - Service: McAfee Firewall Core Service (mfefire) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\\mfefire.exe
O23 - Service: McAfee Validation Trust Protection Service (mfevtp) - McAfee, Inc. - C:\Program Files\Common Files\McAfee\SystemCore\mfevtps.exe
O23 - Service: McAfee Anti-Spam Service (MSK80Service) - McAfee, Inc. - C:\Program Files\Common Files\Mcafee\McSvcHost\McSvHost.exe
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: stllssvr - MicroVision Development, Inc. - C:\Program Files\Common Files\SureThing Shared\stllssvr.exe
O23 - Service: XAudioService - Conexant Systems, Inc. - C:\Windows\system32\DRIVERS\xaudio.exe
End of file - 12374 bytes
