PROBLEM: OK well so i got an Hp Pavilion a1719n and i have a full set of 1024 mb of ram (1GB total) i would like to upgrade and buy two sticks of 1 GB each
My specification are HERE
and my motherboard specification are here
i already know i need a 240 pin ddr2 PC2-4200 MB/sec SDRAM, non ecc unbuffered
What kind of memory can i buy a low density or high density?
which one would an expert recommend?
my a1719n desktop came with 2x512 MB already install
my system is a 32 bit
my motherboard has 4 ram sockets available two or which already have the 512 MB already on which leave two empty ones
so i would like to get 2 sticks of 1Gb each so i can place them on the two empty slot on my motherboard so i can get a total of a full 3GB ram on my system
i don't know if high or low denstiy can give me a full 3 Gb of ram after i install the 2 sticks or 1 GB each would it be hig or low density ram? because i heard that it was either low or high density ram that doesn't address the full set of memory. i want to buy the one that does addres the full set of memory,
Thanks guys.
sorry for my grammar and spelling errors
Thanks guys.
- HP Pavilion a1719n
- 2x 512 MB
