ok so i had to start up windows in safe mode using msconfig...
but now when i try to stop windows from starting up in safe mode i go into msconfig i am able to uncheck safe mode but then i go back into the general tab of msconfig and selective start up is checked but then when i uncheck it, under the boot tab safe mode is checked again.
it's like when i have on thing unchecked the other thing gets checked automatically but i can't get it so that windows starts normally without safe mode...
- Pentium 4 3.0ghz/ Dual Xeon 2.8ghz 8 cores
- Intel D915GUX
- 4gb DDR2 533MHz Memory/4gb DDR2 FB-DIMM
- ATI Radeon x600 Series/ATI Radeon x2600xt
- Dual 19" Gateway FPD1965
- 1280x1024
- 2tb WD Velociraptor 300GB WD 40gb Mac Pro - 500gb, 2x 320gb, 150gb
