Need any help at all
Justspyin
Well i had hidden the files in my folder, has document, videos music, etc.... i hid all of those, well i went to unhide them, and they remain hidden, when i go into the properties it there is no check in the hidden box, what should i do, is this a problem among vista?
You should certainly have a Hidden check box when viewing the properties of files or folders. Instead of looking at the properties of a whole bunch of selections, try narrowing your selection to a single file or folder (you might have picked up a system folder, in which case you cannot turn Hidden off)
Check out this tutorial and double check you're in the right spot
I assume it's not just that you want to see the hidden files or folders. You want to change their attribute, right?
Failing the above, you could use the old attrib command (within a command prompt), something along the lines of:
attrib -h c:\foldername\*.* /s /d
The /s switch will turn off the hidden attribute for all files and files in sub-folders
The /d switch will turn off the hidden attribute for all folders and sub-folders
You could specify file types (or a specific file too) instead of using *.*
    AMD x2 Dual Core 3600+ 1.9GHz
    GigaByte GA-M55SLI-S4
    2GB DDR PC2 5300 RAM
    NVidia GeForce GTS 250 512mb
