Need Advice please
gazz496
a mere mortal
Vista Pro
hi all again
first off thanks to everyone who reads this and can offer any kind of advice.
i can't get media player to play dvd's it tells me to ''lower my resolution'' which is set at 1680 x 1050.
i do this and nothing i take the resolution all the way to 800x600 and nothing gives me the same message so i surmized that their was another problem.
I recently just upgraded my motherboard and ram and ended up having to rebuy vista as my computer was previously factory built.
now i'm wondering if i have missed something or just keep missing an option.
thanks again to all who give me any advice on this.
oh other players work like power dvd but my version is not really compatible with vista so i get loads of warnings and strange things happening, i would really like to get media player working as i like the way it work(thats when it works lol)
Gareth
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
thats the thing i'm not sure i downloaded a tonne of them and still no luck i will keep trying but not sure what else to try !
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
It's odd really that you're having this problem. Vista plays DVDs ok, without the need for any additional codec packs. Uninstall all those packs you installed. It's the only way to be sure that you get rid of the one thats causing this problem.
Then use the link that Bare Foot Kid gave you (Vista Codec Package Homepage). It's the only codec pack you'll ever need - just download the correct version for your Windows Vista (32bit or 64bit).
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
To add to Peter's post:
When you go to the website, regardless of which version of Vista (32bit or 64bit) you have you'll want the Codec package - but if you have the 64bit then you need to get the additional package just underneath that.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
i tried that before i installed any codecs it's like there weren't any there to start with!!
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
No, you install the 32bit codecs *first* and then install the 64bit part.
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
