Narrowing down my s3 problem but need help.
cwatson71
Stay down...fool
I'm still trying to figure out why my dvd drives won't recognize any media after s3 sleep but work fine after a reboot.( it's getting old rebooting everytime i want to watch a movie. :cry: )
In device manager i see the drives, they show up in my comp and bios too..They don't disappear like some problems i've read about...just won't recognize any dvd i put in it until restart.
One thing i notice is that in device manager the power data for the drives show:
Power state mappings:
S0 -> D0
S1 -> Unspecified
S2 -> Unspecified
S3 -> Unspecified
Is that normal? If not how can i "specify" s3 sleep in the drives? All drives are Vista certified and have the latest firmware. I would really appreciate help with this problem.
I'm also thinking maybe the Gear software i use with Itunes may be causing this so i'm googling that too.
    AMD Athlon 64 x2 5200+
    Asus M2N-SLI Deluxe
    4.00 GB Kingston ValueRam
    HIS Radeon HD 4650 1GB 128-bit
    Creative Sound Blaster A-SE 7.1
    Asus 24" & Dell "19" (dual)
    1440 x 900 & 1024 x 768
    Seagate Barracuda 320 gb Seagate FreeAgent 1tb external drive Seagate FreeAgent 500gb external drive
    Rosewill 750w psu
    XCLIO Windtunnel case
    ARCTIC COOLING Freezer 64 Pro 92mm CPU Cooler
    Logitech LX7 Cordless Optical Mouse
    Saitek blue lit keyboard
    over 2mbps T2
Thanks Shawn for the help. I have just set my Multimedia settings to Allow the computer to enter Away Mode. After work i'll be able to test it again and i really appreciate your giving me step 2.
Be back later with results.
    Asus M2N-SLI Deluxe
    Rosewill 750w psu
    over 2mbps T2
That didn't work. Allow the computer to enter Away Mode made my monitor shut off at specified time but the pc wouldn't sleep not even manually. Since my psu is about as loud as a Xbox 360 and my case has two huge blue fans on the side i like to have it all shut down at night, i also tried prevent idling to sleep and after making it all manually sleep the next morning the pc came back on but my monitor wouldn't until a reboot. I'll try step 2..thanks again for the help. I know i'll figure this out eventually. :)
    Asus M2N-SLI Deluxe
    Rosewill 750w psu
    over 2mbps T2
