my vista updater keeps running
foe
I disabled automatic updates and disabled the service, but the updater keeps running. When I boot I get the message: Configuring updates, it runs till 100% back to 80% and to 100. Then I get the message updates have not been configured right, undoing changes...
This way it takes damn long for my laptop to boot...
What sould I do?:confused:
    Intel(R) Core(TM)2 DUO CPU P8400 @ 2.26GHz 2.27GHz
    4G
Hi, and Welcome to the forums.
Is there any reason you don't want the updates? I used to manually choose and install only the ones I needed but just found that too hard to keep up and too insecure. Now I just let it do it's thing and I never have any problems with updates messing things up.
This sounds like you had updates that d'loaded before you disabled the service, and it's still trying to configure them because they hadn't finished, but it can't because the service is disabled. If there are updates that installed but couldn't configure because of the service disabled, the "Update Configuration utility will still run regardless I think. Try re-enabling that service long enough to allow this update to configure and reboot if needed.
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
IWhen I boot I get the message: Configuring updates, it runs till 100% back to 80% and to 100. Then I get the message updates have not been configured right, undoing changes...
Hi Foe,
You can receive that message from adding or removing Windows Components and you can also receive it from applications that have made various system changes not just from Windows Update...
How long ago did this start happening and what changes have you made to your system recently? (install or uninstall, change settings....)
Steven
well, i dont know. I sort of just reformatted...
i'll try reanabling the service for a day or two, but I remember trying it already...
Never the less it keeps saying it ditn't conficure the updates right after running on startup, and deinstalling them afterwarts...
i would like to disable it becouse I got bad experences with updating to often and I dont like it to interrupt me...
I would like to update 1s a month manualy...
    4G
i guess you never now for sure that the message wont show...
but why does it keep telling me it could not install the updates right, even when I enable updater service...?
    4G
ok, seems to help...
I'll let you know if i get the message anyway in a few hours...
*edit* nope, problem is back... only thing shanged is I deleted the logfiles of te program you recomanded me...
I have AVG free, windowsdefender and Ccleaner... could 1 of these be the problem?
*edit* really weird is it hapends always 1s a day and no more or less...
It's almost perfectly daily...?
    4G
please tell me if someone needs more system information, witch kind of information you need en were i can find it.
My laptop is also a bit less quick booting... malware? guess not because of my almost new reformat...
    4G
K I think I finally know wat caused it. If the problem does not return in a day or 3, I'll explain how I fixed it...
    4G
nope, dit not work. What kind of infodo we need? Or should I just reformat again?
My guess is: the updates for office 2003 are the problem. I got my version of ms office 2003 in a way, to make sure I didn't need to pay for it. I used it for years but only now on vista. The updates always failed on XP but in vista, the updates acts like it worked... but I can't remove them...
    4G
I giff up, if nobody can help me in 3 weeks I well reformat again...
    4G
sorry for the dubble posts but I dont like reformatting again... please help!
    4G
so there is no hope? I guess i have to reformat then...
    4G
