My laptop start up error help?
DragonX
my laptop was going really slow so i thought i do a system recovery but there wasn't any dates there for some reason but i restarted my laptop and ever since i been getting windows has encountered a problem i can't get into windows repair brings up the error i did a hole system factory restore a few times now adn still after finished brings up the same error
error code: 0xc00000e9
my laptop runs vista which is what it came with
250gb hard drive, 3gb ram, intel dual-core
any ideas on how to get it working cuz i'm out of ideas
i did also do diagnostic thing but that wasn't any help
and sorry if this is not in right forum i don't reli no much about that site
Windows failed to start. A recent hardware or software change might be the cause.
File: \Windows\system32\config\system
Status: 0xc00000e9
Info: Windows failed to load because the system registry file is missing, or corrupt
the issue can be caused by the damaged system files or hardware device
Unplug ALL non-essential hardware, and do a repair, then startup in safe mode diagnostic startup/selective startup. then do a memtest on memory. This will help you locate the hardware issue (if exists), and /or fix software related issues.
Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
0xc00000e9 Error
To repair/rebuild the Boot Config Data Use the Bootrec.exe Tool
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
How to use the Bootrec.exe tool in the Windows Recovery Environment to troubleshoot and repair startup issues in Windows Vista
  1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  5. Click the operating system that you want to repair, and then click Next.
  6. In the System Recovery Options dialog box, click Command Prompt.
  7. Type Bootrec.exe, and then press ENTER.
Note To start the computer from the Windows Vista DVD, the computer must be configured to start from the DVD drive. For more information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer or contact the computer manufacturer.
Back to the top
Bootrec.exe options
The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
Note If rebuilding the BCD does not resolve the startup issue, you can export and delete the BCD, and then run this option again. By doing this, you make sure that the BCD is completely rebuilt. To do this, type the following commands at the Windows RE command prompt:
  • bcdedit /export C:\BCD_Backup
  • c:
  • cd boot
  • attrib bcd -s -h -r
  • ren c:\boot\bcd bcd.old
  • bootrec /RebuildBcd
Bootrec.exe options
  • c:
  • cd boot
/FixMbr
The /FixMbr option writes a Windows Vista-compatible MBR to the system partition. This option does not overwrite the existing partition table. Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR.
/FixBoot
The /FixBoot option writes a new boot sector to the system partition by using a boot sector that is compatible with Windows Vista. Use this option if one of the following conditions is true:
  • The boot sector has been replaced with a non-standard Windows Vista boot sector.
  • The boot sector is damaged.
  • An earlier Windows operating system has been installed after Windows Vista was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs
The /ScanOs option scans all disks for installations that are compatible with Windows Vista. Additionally, this option displays the entries that are currently not in the BCD store. Use this option when there are Windows Vista installations that the Boot Manager menu does not list.
/RebuildBcd
The /RebuildBcd option scans all disks for installations that are compatible with Windows Vista. Additionally, this option lets you select the installations that you want to add to the BCD store. Use this option when you must completely rebuild the BCD
If you need to create a system recovery disK:
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
my disk doesn't have this when i run from disk it comes up with select language and then just goes to complete restore doesn't have a repair option
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
0xc00000e9 Error
  1. Put the Windows Vista installation disc (or the created recover disk) in the disc drive, and then start the computer.
See above post #2 for commands to rebuild Boot files.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Re-install Windows then. Do not perform a system restore.
Boot into Recovery partition, and Install again.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
that is what i ment what i have done a number of times installed it all fresh but after it done turns on when it loads up it jsut goes black and thats it now not even giving me the error i'm doing windows memory diagnostic tool i done the exstended one but still nothing
Are you completely disconnecting everything when you do the re-imaging?
It is ether a hardware failure, or a issue with the image. Have you tried borrowing a Vista dvd and installing from that?
IF it is still under warranty I would contact the OEM. Did your system come with a vista disk or just the recovery partition? Are you doing a complete re-install, or a repair? What is your model#?
I still think your best bet is a complete destructive re-install of Vista from a disk.(i.e., delete ALL partitions and install vista into unpartitioned space).
As for the re-install to see if the image is bad, you can try any Vista disk (do not enter the key), and If the install is ok, then you have a bad image, if on the other hand, the error still occurs it may be a bad hardware issue.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
Well ive disconnected everything and its not working. The only disk i got with it is the product recovery disk. My model number is PSAF5E- 002005KS. Toshiba EQUIUM A200-1VO. Where can i get a vista disk from?
This evidently is a common problem.
Let me ask you this, Is the re-install completing sucessfully or aborting (i.e., cannot find hard drive?)
Toshiba Equium A200 1VO Boot Troubles - Tech Support Forum
The problem may be you need to load sata drivers at install screen either off your driver disk or thumb drive or floppy.
The following eror will occur if your Recovery partition is missing (deleted/corrupted):
>"No valid backup locations could be found."
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
yeah it finds it fine all pick up on my hard drive and when i do it it all finished succsseful and when reinstalled it fins fine and that lot no errors or that so i don't no
i made a dvd of what you gave me earlier but i don't see that partition one there just the bit where it has sysem restore and start up repair command promt
What?:confused:
I have no idea what you just wrote.
The disk I linked you to earlier is just a recovery Utility disk. To see the partitions you need to boot into the recovery Partition or the Recovery disks you created for your PC.
    Realtek HD
    WUXGA 17"
    1920X1200
    10 mbps/2 mbps
i don't think i have a recovery partition its no where to be seen and yeah i loaded the disk yesterday a few times and tried everything and nothing worked.
and i never seen that screen in my life
try a start up recovery and says if you have recently attached a device to this computer, such as a camera ad that blah blah but nothing has been attached and it poped up with the send information box and these are the details from it:
Problem signature:
Problem event name: StartupRepairV2
Prolem Signature 01: ExternalMedia
Prolem Signature 02: 6.0.6000.16386.6.0.6000.16386
Prolem Signature 03: 6
Prolem Signature 04: 131074
Prolem Signature 05: FailureDuringSetup
Prolem Signature 06: NoBootFailure
Prolem Signature 07: 0
Prolem Signature 08: 0
Prolem Signature 09: unknown
Prolem Signature 10: 1169
OS Version: 6.0.6000.2.0.0.256.1
Locale iD: 1033
Read our privacy statement:
Microsoft Online Crash Analysis
tried the toshiba wizard thing you gave me i hold 0 while loads up but doesn't bring up anything just does it usal self and i no i have a winre like partition but i don't no how to access that doesn't appear in boot menu or anything
