My fatal1ty problem ( microphone )
snap1993
i cant find the answer to my problem in the creative site ....
my problem is that my microphone use to work perfectly yesterday and today my microphone deactivate it self and then re-activate it self but starts doing a buzz sound ... and when i try to talk it makes my voice buzzy too
can you please help me
I assumes you have one of the X-Fi cards from Creative then.
First ensure you're all patched up.
Try changing Audio modes, sometimes changing that kicks things back into life.
Try setting the mode you're using back to default settings.
Do you have one of the cards with the break-out box? - If so try changing where your mic is plugged in and see if that makes a difference.
Tried the obvious "reboot fixes most things" trick? ;)
Just a couple o things to try :)
    2x AMD FX-74 @ 3.0GHz
    ASUS L1N64-SLI
    4GB OCZ Reaper DDRII
    2x BFG 8800GTX OC 768MB (SLI)
    Creative X-Fi Fatl1ty
    HP L2045w
    2x 500GB Samsung T166 SATAII
    Enermax Galaxy 1000W PSU
    Thermaltake Armor Extreme Case
    Razer DeathAdder
    Microsoft Multimedia Keyboard
    8Mb ADSL (UK Online)
Or you could just get a sound card that works much better for Vista 64.
Creative seems to have just stopped caring about costumer support at all.
I had a creative Audigy EX which worked fine for WinXP however was worthless on Vista 64.
I went with a HT Omega Claro and it is excellent in every way.
HT Omega - Claro
    Home Built
    Q6600 @ 2.66ghz
    Asus Maximus Formula
    8GB Patriot PC2 6400
    Geforce 8800GT 512mb
    HT Omega Claro Halo
    Dell 21" 2001FP
    1600X1200
    Western Digital 640GB 32mb cache
    Cooler Master 750W
    Cooler Master ATC 201C-SX1
    Stock Intel CPU fan 4 80X80mm case fans 1 120mm case fan
    Logitech MX Revolution
    Logitech G15 gaming keyboard
    RR cable 10Mbps with 16Mbps boost
    Sennheiser PC350 Headset
