My doucments display fields
Foghorn
This may have been covered somewhere, but I couldn't figure what to search on.
This is happening on two different Vista machines.
If I open "My Documents", details view, the folders are listed "normally" showing date modified, size, etc.
But, if I open a sub-folder, the contents are displayed as pictures, Name, Date Taken, Tag, etc.
Then, if I open another sub-folder, the contents are listed as music with fields, name, artist, album, etc.
Really weird.
IF, I navigate to the folders under My Computer, they display normally and all is good.
I have TONS of documents, so I have them sorted by year. 2004, 2005, 2006, yadda, yadda, yadda. Then by topic or whatever underneath. I typically list them by date so that my most recent files are grouped together, but now listing by date isn't an option and it's tough to find anything.
I've tried My Documents, Properties, Customize, Template, Documents, Apply to sub-folders. Did no good.
Anyone have any ideas?
Thanks,
Fog
Have you tried changing the folder view to detail?
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
Did you open a file in each sub-folder after changing the properties ? ?
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
Yes to both.
The problem shows itself in detail view.
And yes, I set the properties for My Documents, then opened my documents (fine) then opened folder 2009 (listed as pictures), then opened folders Downloads (listed as music).
Works fine if I enter under My Computer
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    19" Viewsonic and Sony 26" S Series TV
    1920x1080
    Sata (1 TB) and IDE (350GB)
    Optical (Wireless)
    Multimedia (Wireless)
    2MB
