My desktop background has problems
IrregularHonour
Hello, I'm new on here. I decided to join the forums and post because I found an old outdated thread that described the exact same problem as I am currently experiencing. I googled the issue, but this was the only place that seemed to relate to my problem.
The thread I'm referring to is called "Black Dots On Desktop Background" and it was posted by charleyvonne. I quote it below.
Hi folks,
I recently downloaded a wallpaper changer program called Winvista. As soon as I started to play with the different wallpapers on my desktop, I couldn't help but notice that it had completely cocked up! It seems rather odd, behind the display picture there are a series of grid formad dots, very small and regemented. These move around when I open windows over them or when I select desktop icons. I had a go at changing my resolution, display settings, themes, effects and tried using different background pictures. I've restarted a few times and have selected to use different solid colours, but these dots don't budge.
The program isn't running now, but I still have the dots! I could try to put up a screen cap of my desktop if it helps?
Any info on this would be greatly appreciated!
Many thanks."
I downloaded Winvista, a wallpaper changer program, just as this member did, and then black dots appeared on the background colour of my desktop. It is very annoying, and I didn't experience the problem until I downloaded Winvista. I have deleted the Winvista program, since it didn't really work for me anyway, and also I've tried system restore- with no change.
I am VERY anxious to correct this issue. Can someone give me some advice? I've checked the advice given on the outdated thread- none of it seemed to offer the solution I need. Also, in the outdated thread charleyvonne didn't seem to find a solution either.
Please someone tell me that I can do something about this!!
have you checked your resolution and color depth?
    Aleinware Area-51
    core 2 extreme x9000 2.8 Ghz
    4 Gig
    (2) Nvidia 8800m GTX in Sli
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    (2) seagate 7200rpm in RAID 0 (1) maxtor external 1 terabyte firewire
    laptop
    logitech Anywhere Mouse and built-in touchpad
    a really spiffy backlit one that i can change color ;>)
    Cable
color depth is represented as 16bit, 32bit, etc. check the settings in "display properties" applet in CONTROL PANEL.
    Aleinware Area-51
    4 Gig
    Onboard RealTek
    42" JVC LCD HDTV
    1920x1080p 32 bit
    laptop
    Cable
I couldn't find what you said in the control panal, so I just went to 'personalize' and checked the settings there. I tried changing it from 32bit down to 16bit, which was my only other option. It made no difference. :(
