You should upgrade or use an
alternative browser .
Must unplug and replug monitor after sleep or startup
The last week my monitor has been hissing and has now started to remain black after startup or coming out of sleep. I have to unplug and replug the VGA cord a few times before the screen comes back on. It tries to come on on startup but all you hear is this loading hiss and a quick flash of screen. After I get it working it works fine and will even come back on if I play with the on off button. I have already replaced the VGA cord with a new one so that's not the issue. I am running Vista 64 Premium Home on a HP pavilion. I've had the monitor for 4 years with no issues. I have not updated , installed or changed anything before this started. Any help will be appreciated
americano
Hello robang13,
Have you tried to update or re-install your display driver through the device manager?
HP Pavilion Elite
Some Amount of Motherness
6.O GB RAM
Some Amount of Soundness
1440x900 & 1440x900
WD Caviar Blue 500GB
Some Amount of Voltageness
Hp Pavilion Elite Case
Some Amount of Coolingness
HP: M/N:M-SBQ133
HP: Model Number: KB0911
Comcast: 20 MB/S
Do you mean my NVIDIA?
After I get the monitor to work it stays on. Do you think this is a driver issue? Why is there this hum that was never there before?
Network Enthusiast
It may be your Power supply going or a Transformer that has broken Does this happen with any other Moniter?
Intel Core i5 2400 @ 3.10GHz
Foxconn H67MP-S/-V/H67MP
8.0GB DDR3 @ 665MHz (2GBx4)
AMD HD Radeon 6870
SMB1930NW (1440x900@60Hz)
Novatech Night
Dell HID-compliant mouse
I already changed the power cord and the VGA cord. I'm going to pick up another monitor tonight to see if it's just this one. Just seems weird that it works once powered fine.
americano
If there's a humming sound that was not there before it might be just that monitor.
But yeah, if you have a nVidia display adapter then go ahead and update /re-install it.
HP Pavilion Elite
6.O GB RAM
1440x900 & 1440x900
HP: M/N:M-SBQ133
Comcast: 20 MB/S
Yep, seems like it was the monitor. Of course it came out of warranty just 2 months ago!!
Thanks for everyones answers!!
americano
Glad you were able to figure it out.
HP Pavilion Elite
6.O GB RAM
1440x900 & 1440x900
HP: M/N:M-SBQ133
Comcast: 20 MB/S
