Multiple networks problem, limited connectivity
Womacks23
Having a problem with vista and internet. I connect with ethernet directly to a dsl modem. Everything has been working great for months and for some unknown reason the internet kicks out.
Basically vista is thinking I'm connecting to "multiple networks", I can log on to my ppoe connection fine but there is no active internet connection. I've checked up on all the related problems and disabled IPv6. Nothing seems to work. Also updated all drivers.
I know the problem is not with the modem because I'm using it now with a mac to type up this report.
Here is my ipconfig report. My first thoughts are that something is wrong in that I have 60 tunnel adapters. I'm not really sure what the problem is. The Japanese is from a Japanese system. Tunnel adapter ローカル エリア = Local Area.
ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : David-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
PPP adapter Broadband Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadband Connection
Physical Address. . . . . . . . . :
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 218.219.253.221(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 202.224.32.1
202.224.32.2
NetBIOS over Tcpip. . . . . . . . : Disabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Marvell Yukon 88E8057 PCI-E Gigabit Ether
net Controller
Physical Address. . . . . . . . . : 00-1D-72-C7-E5-DC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration IPv4 Address. . : 169.254.240.81(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter ローカル エリア接続* 6:
Description . . . . . . . . . . . : isatap.{83B2AB93-EC97-41A0-B998-4F3115E50
E67}
Tunnel adapter Local Area Connection* 4:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter ローカル エリア接続* 7:
Description . . . . . . . . . . . : 6TO4 Adapter
Tunnel adapter ローカル エリア接続* 11:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter ローカル エリア接続* 13:
E67}
Tunnel adapter ローカル エリア接続* 14:
Tunnel adapter ローカル エリア接続* 16:
Tunnel adapter ローカル エリア接続* 17:
Tunnel adapter Local Area Connection* 5:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #7
Tunnel adapter ローカル エリア接続* 19:
Tunnel adapter ローカル エリア接続* 20:
Tunnel adapter ローカル エリア接続* 21:
Tunnel adapter ローカル エリア接続* 22:
Tunnel adapter ローカル エリア接続* 23:
Tunnel adapter ローカル エリア接続* 24:
Tunnel adapter ローカル エリア接続* 25:
Tunnel adapter ローカル エリア接続* 26:
Tunnel adapter ローカル エリア接続* 27:
Tunnel adapter ローカル エリア接続* 28:
Tunnel adapter ローカル エリア接続* 29:
Tunnel adapter ローカル エリア接続* 30:
Tunnel adapter ローカル エリア接続* 31:
Tunnel adapter ローカル エリア接続* 32:
Tunnel adapter ローカル エリア接続* 33:
Tunnel adapter ローカル エリア接続* 34:
Tunnel adapter ローカル エリア接続* 35:
Tunnel adapter ローカル エリア接続* 38:
Tunnel adapter ローカル エリア接続* 40:
Tunnel adapter ローカル エリア接続* 41:
Tunnel adapter ローカル エリア接続* 42:
Tunnel adapter ローカル エリア接続* 43:
Tunnel adapter ローカル エリア接続* 44:
Tunnel adapter ローカル エリア接続* 45:
Tunnel adapter ローカル エリア接続* 46:
Tunnel adapter ローカル エリア接続* 47:
Tunnel adapter ローカル エリア接続* 48:
Tunnel adapter ローカル エリア接続* 53:
E67}
Tunnel adapter ローカル エリア接続* 55:
E67}
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #5
IPv6 Address. . . . . . . . . . . : 2002:dadb:fddd::dadb:fddd(Preferred)
202.224.32.2
Tunnel adapter ローカル エリア接続* 58:
Tunnel adapter ローカル エリア接続* 59:
Tunnel adapter ローカル エリア接続* 60:
