Solved msg bottom right of desktop
Could some please help?
I just re installed Vista Home Premium. It is an upgrade copy. I did a clean install which I have done many times before. No problems.
I just noticed this morning in the lower right corner
Windows Vista (tm)
Evaluation Copy. Build 6002
this caught my eye because I am also using Windows 7 on another maching and see the build number of that sysem.
I bought the copy of Vista and thought everything was OK.
Larry
    Windows Vista Home Premium 32bit
    Intel Celeron M
    DSL 1.5gig
Windows Vista (tm)
Larry
I believe this happens when you have not validated your copy of windows after sometime, but I may be wrong...have you validated windows since the install?
Also, have you installed Vista SP2 Beta? if so, that would cause the watermark as well.
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    6gb MUSHKIN DDR3 1866
    TWO x EVGA NVidia GTX 285
    Soundblaster Extreme
    ASUS 24inch 2ms LCD
    1920x1080
    4 x OCZ Vertex 60GB, 1 x Western Digital Velociraptor 300GB, 1TB Western Digital Caviar Black
    Corsair 1000W
    Coolermaster HAF 932
    Water cooled
    Microsoft Regular USB w/wheel
    Saitek Cyborg Deluxe
    Cable 15mbps
Hi Larry,
That would from the pre-release Vista SP2. I have the same message to. :)
When the final RTM version of the Vista SP2 is released, you will need to uninstall your current one first to update to the new one though.
Hi Larry,
:p i was close!!! ;)
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
Lol. ;)
yes I did install sp2.
thank you for the response.
    Intel Celeron M
    DSL 1.5gig
You're welcome Shipinomore. :)
Brink;
A quick note. I deleted that beta sp2 and after it did the uninstall and restart and completed the delete. the message is still there and now it has build 6001. I believe in the original request for help the build was 6002.
Anything to worry about???
Thanks Larry.
    Intel Celeron M
    DSL 1.5gig
Na, nothing to worry about. It may even go away after a few restarts though now that you are back to only the activated Vista SP1.
Brink correct your are. It disappeared this morning.
Larry.
    Intel Celeron M
    DSL 1.5gig
That's great news Larry. :)
Thank you for posting back to confirm it.
